[Mapserver-users] Virtual Spatial Data Wiki Question
Paul Spencer
spencer at dmsolutions.ca
Thu Mar 4 18:47:54 EST 2004
if it works with ogrinfo and not with mapserver/mapscript then you need
a more recent version of mapserver binaries. It is not sufficient to
replace gdalxx.dll, you must have a mapserver that was compiled against
the newer gdal source code. You can find the latest 4.1 compiled for
windows as of today here:
http://www.maptools.org/dl/mapserver-4.1-dev-win32-php4.3.4.zip
Cheers,
Paul
Nikolai Schwertner wrote:
> Hi all,
> I am following the instructions from the wiki on "Virtual Spatial Data" to
> create a virtual layer from an ODBC data source (under Windows 2000). The
> OVF file works great with ogrinfo.exe, but fails with the following message
> when I try to load it in MapServer:
> msDrawMap(): Image handling error. Failed to draw layer named 'sb_pt'.
> msOGRFileOpen(): OGR error. Open failed for OGR connection
> `w:\app\virtual.ovf'. File not found or unsupported format.
> Past posts suggest that this problem may be related to the permissions of
> the Apache user over the OVF file. I don't think that this is the problem in
> this case. All permissions are in order and Apache has no problem accessing
> the file.
> I will appreciate any suggestions regarding this problem.
> Sincerely,
> Nikolai
> Nikolai Schwertner
> TCCS/Academic Technology
> Tufts University
> Medford, MA 02155
> Phone: 617.627.2821
> Fax: 617.627.3667
> Email: nikolai.schwertner at tufts.edu
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
|Paul Spencer spencer at dmsolutions.ca |
|Applications & Software Development |
|DM Solutions Group Inc http://www.dmsolutions.ca/|
