[Mapserver-users] Distance Calculation
Map Guy
mappington at yahoo.com
Fri Mar 5 09:58:30 EST 2004
--0-196938625-1078498710=:46912
Content-Type: text/plain; charset=us-ascii
Thank you very much for your help so far.
Up to this point we have been making all of calculations for our maps in lat/long degrees. So, for instance, our map extent is given in lat/long degrees. This acts as a window into our source geographic pjoection layers. Based on what you have said, we now want our output to be projected to UTM. Do we now need to convert all of our lat/long degrees to meters for this to work (what is a good way to do this, if so)? An example would be our map extent - does this now need to be in meters? Is there no way to specify everything in lat/long degrees for accessing our source data and then have the end result projected to UTM? Our map file (simplified) is at the end of this email.
NAME MAPREQUEST
SYMBOLSET "maprequest.sym"
EXTENT -178.226733 18.914590 -66.953248 71.381356 # Set dynamically (Does this now need to be in meters?)
SIZE 586 586
UNITS DD # What should this be?
TRANSPARENT OFF
FONTSET "maprequest.fon"
IMAGECOLOR 204 255 255
IMAGETYPE PNG
SHAPEPATH /layers/
PROJECTION
"init=epsg:26915"
END
LAYER
NAME "Boundary"
DATA "cty90"
STATUS ON
TYPE POLYGON
TEMPLATE "foo"
CLASS
COLOR 255 255 204
OUTLINECOLOR 255 255 204
END
PROJECTION
"proj=latlong"
END
END
Thanks again!
Ed McNierney <ed at topozone.com> wrote:
Yes, that helps a lot. First, you MUST project your data if you're going to create a raster image of it, unless your users have ellipsoidal monitor screens <g>. Using lat/lon coordinates as X/Y coordinates is a projection, too - it's just not a very useful one for most purposes. If you're going to measure distances you need appropriately projected maps.
You might do best with the UTM projection family. It is simple, common, and easy to use. It is not an equidistant projection and there will be a VERY small distortion, but for areas as small as yours I think it will be completely invisible. There are other more accurate projections (equidistant conic, for example) that require more work on your part.
You do, however, need to choose the appropriate UTM zone for each map you make, based on the longitude of the center point. If you try to make a map that is very small scale (showing a large portion of the country) it will look strange around the edges. But if you make maps of less than a few hundred miles in extent no one will notice.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
Sent: Wednesday, March 03, 2004 3:29 PM
To: Ed McNierney
Cc: mapserver-users at lists.gis.umn.edu
Subject: RE: [Mapserver-users] Distance Calculation
We are trying to map underlying layers like streets, parks, cities, etc. taken from TIGER for the United States. Then on top of this we are drawing a ring usually less than 20 miles with the center being the center of the map. Then we are mapping points given to us with lat/lon. In the legend we put the distance of the point from the center of the map. It is this distance which when done with Great Circle calc raised the red flag because the distance would put the point outside the circle when it was being drawn inside the circle. If we used Cartesian distance, then the distance would be off.
So, based on your answers, we MUST project our data in order for our distance shown in the legend to be accurate and also match what we draw on the map, right?
Thanks and let me know if you need more detail to provide suggestions.
Ed McNierney <ed at topozone.com> wrote: I don't know what a "Cartesian" distance in miles means when your units are in degrees and the conversion between degrees and miles depends on the length and the orientation of the line.
As I said, if you can provide more detail we can offer more advice. For example, if all your distances are at a "small scale", that's more detail (you didn't say that before). That helps define the problem better and helps us suggest solutions. Please describe the problem you're trying to solve and we'll help!
- Ed
Ed McNierney
ed at topozone.com
(978) 251-4242
Sent: Wednesday, March 03, 2004 3:15 PM
To: Ed McNierney
I know it is a very simple question, but I didn't think the results would be so different at such a small scale. Would you tell me if these results seem right:
Point 1 (Lon,Lat): -87.6552,41.9148
Point 2 (Lon,Lat): -87.8081,41.8884
Cartesian Distance between Point 1 and 2 in miles: 11.2
Great Circle (assuming sphere) Distance between Point 1 and 2: 8.1
Thanks again.
First, please ALWAYS reply to the entire list. That way everyone benefits from the conversation, and the first person to answer your question doesn't have to make a lifetime commitment to further questions!
Yes, of course you can choose one projection for your entire set of data. Or you could switch based on what you're mapping. The reason there are so many map projections is because each has different properties, and therefore does some things well and other things less well. The classic Mercator projection is excellent if you are navigating with a compass; it is very poor if you're trying to persuade someone that Brazil is several times larger than Greenland.
You also need to have a feel for what level of accuracy you need for your measurements. The UTM family of projections is popular in part because it allows fairly accurate distance measurements, does not distort shapes badly, and is easy to use. However, you need 10 different UTM zones to cover the lower 48 states. If you need even more accuracy a custom Transverse Mercator projection centered on the longitude of your central point would be better.
Mapping large areas in a single map is harder to do in an appealing way than mapping small areas, because spatial distortion becomes more obvious.
If you can provide a bit more detail on what you're trying to do we can offer more advice.
- Ed
Ed McNierney
ed at topozone.com
(978) 251-4242
Sent: Wednesday, March 03, 2004 2:01 PM
To: Ed McNierney
Thank you for your quick response.
Is it possible to choose one projection for my entire set of data which includes the whole United States (TIGER data). Or, do I somehow have to switch based on what I am mapping? If the latter is true, then do you have a suggestion on how I would do that?
Again, point me elsewhere if I am pushing in the wrong direction.
Thank you,
Map Guy
Dear Map Guy -
If you draw an 8-mile ring on a "geographic projection" map it will not be a circle. If you create a map with a 20-mile extent it will not be a square.
Maps using "geographic projection" are useless for making distance measurements; you simply cannot do them in any kind of sensible way. The width of the top edge (east-west) of your "20 mile" image is DIFFERENT than the width of the bottom edge. In fact, each row of pixels running across the image has a different width in miles/feet/meters because they're all different distances from the Equator. That's why the set of all points 8 miles from a given point is not a circle or ring; it's not even an ellipse.
You need to choose a projected coordinate system in order to do reasonable distance measurements.
- Ed
Ed McNierney
ed at topozone.com
(978) 251-4242
Sent: Wednesday, March 03, 2004 12:21 PM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] Distance Calculation
We use TIGER data for our mapping data source. We use a geographic projection (lat/lon). When we draw an 8 mile ring on a map with a 20 mile extent, and we plot a point and calculate the distance from the center using Great Circle we get 7.5 miles. Using a Cartesian calculation we get 8.2 miles.
2 questions:
1. Should we be seeing this much difference in distances?
2. What is the correct way to draw a ring on a map using a geographic projection (lat/lon) and display distances between points using Great Circle without the distance placing the point incorrectly inside or outside the ring?
Thanks in advance.
P.S. Point me somewhere else if this is the wrong place to ask these questions.
Do you Yahoo!?
Yahoo! Search - Find what youre looking for faster.
Do you Yahoo!?
Do you Yahoo!?
Do you Yahoo!?
Do you Yahoo!?
Content-Type: text/html; charset=us-ascii
<DIV>Thank you very much for your help so far.</DIV>
<DIV> </DIV>
<DIV>Up to this point we have been making all of calculations for our maps in lat/long degrees. So, for instance, our map extent is given in lat/long degrees. This acts as a window into our source geographic pjoection layers. Based on what you have said, we now want our output to be projected to UTM. Do we now need to convert all of our lat/long degrees to meters for this to work (what is a good way to do this, if so)? An example would be our map extent - does this now need to be in meters? Is there no way to specify everything in lat/long degrees for accessing our source data and then have the end result projected to UTM? Our map file (simplified) is at the end of this email. </DIV>
<DIV> </DIV>
<DIV>NAME MAPREQUEST<BR>SYMBOLSET "maprequest.sym"<BR>EXTENT -178.226733 18.914590 -66.953248 71.381356 # Set dynamically (Does this now need to be in meters?)<BR>SIZE 586 586<BR>UNITS DD # What should this be?<BR>TRANSPARENT OFF<BR>FONTSET "maprequest.fon"<BR>IMAGECOLOR 204 255 255<BR>IMAGETYPE PNG<BR>SHAPEPATH /layers/</DIV>
<DIV><BR>PROJECTION<BR> "init=epsg:26915"<BR>END<BR></DIV>
<DIV>LAYER<BR> NAME "Boundary"<BR> DATA "cty90"<BR> STATUS ON<BR> TYPE POLYGON<BR> TEMPLATE "foo"<BR> CLASS<BR> COLOR 255 255 204<BR> OUTLINECOLOR 255 255 204<BR> END<BR> PROJECTION<BR> "proj=latlong"<BR> END</DIV>
<DIV>END<BR><BR>Thanks again!</DIV>
<DIV> </DIV>
<DIV><BR><B><I>Ed McNierney <ed at topozone.com></I></B> wrote:</DIV>
<BLOCKQUOTE class=replbq style="PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #1010ff 2px solid">
<META content="MSHTML 6.00.2800.1400" name=GENERATOR>
<DIV dir=ltr align=left><SPAN class=284524120-03032004><FONT face=Arial color=#0000ff size=2>Yes, that helps a lot. First, you MUST project your data if you're going to create a raster image of it, unless your users have ellipsoidal monitor screens <g>. Using lat/lon coordinates as X/Y coordinates is a projection, too - it's just not a very useful one for most purposes. If you're going to measure distances you need appropriately projected maps.</FONT></SPAN></DIV>
<DIV dir=ltr align=left><SPAN class=284524120-03032004><FONT face=Arial color=#0000ff size=2></FONT></SPAN> </DIV>
<DIV dir=ltr align=left><SPAN class=284524120-03032004><FONT face=Arial color=#0000ff size=2>You might do best with the UTM projection family. It is simple, common, and easy to use. It is not an equidistant projection and there will be a VERY small distortion, but for areas as small as yours I think it will be completely invisible. There are other more accurate projections (equidistant conic, for example) that require more work on your part.</FONT></SPAN></DIV>
<DIV dir=ltr align=left><SPAN class=284524120-03032004><FONT face=Arial color=#0000ff size=2>You do, however, need to choose the appropriate UTM zone for each map you make, based on the longitude of the center point. If you try to make a map that is very small scale (showing a large portion of the country) it will look strange around the edges. But if you make maps of less than a few hundred miles in extent no one will notice.</FONT></SPAN></DIV>
<DIV dir=ltr align=left><SPAN class=284524120-03032004> <FONT face=Arial color=#0000ff size=2>- Ed</FONT></SPAN></DIV>
<P><FONT size=2>Ed McNierney<BR>President and Chief Mapmaker<BR>TopoZone.com / Maps a la carte, Inc.<BR>73 Princeton Street, Suite 305<BR>North Chelmsford, MA 01863<BR>ed at topozone.com<BR>(978) 251-4242 </FONT></P></SPAN></DIV><BR>
<DIV class=OutlookMessageHeader lang=en-us dir=ltr align=left>
<HR tabIndex=-1>
<FONT face=Tahoma size=2><B>From:</B> Map Guy [mailto:mappington at yahoo.com] <BR><B>Sent:</B> Wednesday, March 03, 2004 3:29 PM<BR><B>To:</B> Ed McNierney<BR><B>Cc:</B> mapserver-users at lists.gis.umn.edu<BR><B>Subject:</B> RE: [Mapserver-users] Distance Calculation<BR></FONT><BR></DIV>
<DIV></DIV>
<DIV>
<DIV dir=ltr align=left><FONT face=Arial size=2><SPAN class=577011319-03032004>We are trying to map underlying layers like streets, parks, cities, etc. taken from TIGER for the United States. Then on top of this we are drawing a ring usually less than 20 miles with the center being the center of the map. Then we are mapping points given to us with lat/lon. In the legend we put the distance of the point from the center of the map. It is this distance which when done with Great Circle calc raised the red flag because the distance would put the point outside the circle when it was being drawn inside the circle. If we used Cartesian distance, then the distance would be off. </SPAN></FONT></DIV>
<DIV dir=ltr align=left><FONT face=Arial size=2><SPAN class=577011319-03032004></SPAN></FONT> </DIV>
<DIV dir=ltr align=left><FONT face=Arial size=2><SPAN class=577011319-03032004>So, based on your answers, we MUST project our data in order for our distance shown in the legend to be accurate and also match what we draw on the map, right?</SPAN></FONT></DIV>
<DIV dir=ltr align=left><FONT face=Arial size=2><SPAN class=577011319-03032004>Thanks and let me know if you need more detail to provide suggestions.</SPAN></FONT></DIV><BR><BR><B><I>Ed McNierney <ed at topozone.com></I></B> wrote:
<DIV dir=ltr align=left><SPAN class=336382120-03032004><FONT face=Arial color=#0000ff size=2>I don't know what a "Cartesian" distance in miles means when your units are in degrees and the conversion between degrees and miles depends on the length and the orientation of the line.</FONT></SPAN></DIV>
<DIV dir=ltr align=left><SPAN class=336382120-03032004><FONT face=Arial color=#0000ff size=2></FONT></SPAN> </DIV>
<DIV dir=ltr align=left><SPAN class=336382120-03032004><FONT face=Arial color=#0000ff size=2>As I said, if you can provide more detail we can offer more advice. For example, if all your distances are at a "small scale", that's more detail (you didn't say that before). That helps define the problem better and helps us suggest solutions. Please describe the problem you're trying to solve and we'll help!</FONT></SPAN></DIV>
<DIV dir=ltr align=left><SPAN class=336382120-03032004> <FONT face=Arial color=#0000ff size=2>- Ed</FONT></SPAN></DIV>
<HR tabIndex=-1>
<FONT face=Tahoma size=2><B>From:</B> Map Guy [mailto:mappington at yahoo.com] <BR><B>Sent:</B> Wednesday, March 03, 2004 3:15 PM<BR><B>To:</B> Ed McNierney<BR><B>Cc:</B> mapserver-users at lists.gis.umn.edu<BR><B>Subject:</B> RE: [Mapserver-users] Distance Calculation<BR></FONT><BR></DIV>
<DIV></DIV>
<DIV>I know it is a very simple question, but I didn't think the results would be so different at such a small scale. Would you tell me if these results seem right:</DIV>
<DIV> </DIV>
<DIV>Point 1 (Lon,Lat): <FONT size=2>-87.6552,41.9148</FONT></DIV>
<DIV>Point 2 (Lon,Lat): <FONT size=2>-87.8081,<FONT size=2>41.8884</FONT></FONT></DIV>
<DIV> </DIV>
<DIV>Cartesian Distance between Point 1 and 2 in miles: 11.2</DIV>
<DIV>Great Circle (assuming sphere) Distance between Point 1 and 2: 8.1 </DIV>
<DIV> </DIV>
<DIV>Thanks again.<BR><BR><B><I>Ed McNierney <ed at topozone.com></I></B> wrote:</DIV>
<DIV dir=ltr align=left><FONT face=Arial color=#0000ff size=2><SPAN class=577011319-03032004>First, please ALWAYS reply to the entire list. That way everyone benefits from the conversation, and the first person to answer your question doesn't have to make a lifetime commitment to further questions!</SPAN></FONT></DIV>
<DIV dir=ltr align=left><FONT face=Arial color=#0000ff size=2><SPAN class=577011319-03032004></SPAN></FONT> </DIV>
<DIV dir=ltr align=left><FONT face=Arial color=#0000ff size=2><SPAN class=577011319-03032004>Yes, of course you can choose one projection for your entire set of data. Or you could switch based on what you're mapping. The reason there are so many map projections is because each has different properties, and therefore does some things well and other things less well. The classic Mercator projection is excellent if you are navigating with a compass; it is very poor if you're trying to persuade someone that Brazil is several times larger than Greenland.</SPAN></FONT></DIV>
<DIV dir=ltr align=left><FONT face=Arial color=#0000ff size=2><SPAN class=577011319-03032004>You also need to have a feel for what level of accuracy you need for your measurements. The UTM family of projections is popular in part because it allows fairly accurate distance measurements, does not distort shapes badly, and is easy to use. However, you need 10 different UTM zones to cover the lower 48 states. If you need even more accuracy a custom Transverse Mercator projection centered on the longitude of your central point would be better.</SPAN></FONT></DIV>
<DIV dir=ltr align=left><FONT face=Arial color=#0000ff size=2><SPAN class=577011319-03032004>Mapping large areas in a single map is harder to do in an appealing way than mapping small areas, because spatial distortion becomes more obvious.</SPAN></FONT></DIV>
<DIV dir=ltr align=left><FONT face=Arial color=#0000ff size=2><SPAN class=577011319-03032004>If you can provide a bit more detail on what you're trying to do we can offer more advice.</SPAN></FONT></DIV>
<DIV dir=ltr align=left><FONT face=Arial color=#0000ff size=2><SPAN class=577011319-03032004> - Ed</SPAN></FONT></DIV>
<P><FONT size=2>Ed McNierney<BR>President and Chief Mapmaker<BR>TopoZone.com / Maps a la carte, Inc.<BR>73 Princeton Street, Suite 305<BR>North Chelmsford, MA 01863<BR>ed at topozone.com<BR>(978) 251-4242 </FONT></P></SPAN></FONT></DIV><BR>
<HR tabIndex=-1>
<FONT face=Tahoma size=2><B>From:</B> Map Guy [mailto:mappington at yahoo.com] <BR><B>Sent:</B> Wednesday, March 03, 2004 2:01 PM<BR><B>To:</B> Ed McNierney<BR><B>Subject:</B> RE: [Mapserver-users] Distance Calculation<BR></FONT><BR></DIV>
<DIV></DIV>
<DIV>Thank you for your quick response.</DIV>
<DIV> </DIV>
<DIV>Is it possible to choose one projection for my entire set of data which includes the whole United States (TIGER data). Or, do I somehow have to switch based on what I am mapping? If the latter is true, then do you have a suggestion on how I would do that?</DIV>
<DIV> </DIV>
<DIV>Again, point me elsewhere if I am pushing in the wrong direction.</DIV>
<DIV> </DIV>
<DIV>Thank you,</DIV>
<DIV> </DIV>
<DIV>Map Guy<BR><BR><B><I>Ed McNierney <ed at topozone.com></I></B> wrote:</DIV>
<DIV dir=ltr align=left><SPAN class=606261418-03032004><FONT face=Arial color=#0000ff size=2>Dear Map Guy -</FONT></SPAN></DIV>
<DIV dir=ltr align=left><SPAN class=606261418-03032004><FONT face=Arial color=#0000ff size=2></FONT></SPAN> </DIV>
<DIV dir=ltr align=left><SPAN class=606261418-03032004><FONT face=Arial color=#0000ff size=2>If you draw an 8-mile ring on a "geographic projection" map it will not be a circle. If you create a map with a 20-mile extent it will not be a square.</FONT></SPAN></DIV>
<DIV dir=ltr align=left><SPAN class=606261418-03032004><FONT face=Arial color=#0000ff size=2>Maps using "geographic projection" are useless for making distance measurements; you simply cannot do them in any kind of sensible way. The width of the top edge (east-west) of your "20 mile" image is DIFFERENT than the width of the bottom edge. In fact, each row of pixels running across the image has a different width in miles/feet/meters because they're all different distances from the Equator. That's why the set of all points 8 miles from a given point is not a circle or ring; it's not even an ellipse.</FONT></SPAN></DIV>
<DIV dir=ltr align=left><SPAN class=606261418-03032004><FONT face=Arial color=#0000ff size=2>You need to choose a projected coordinate system in order to do reasonable distance measurements.</FONT></SPAN></DIV>
<DIV dir=ltr align=left><SPAN class=606261418-03032004> <FONT face=Arial color=#0000ff size=2>- Ed</FONT></SPAN></DIV>
<HR tabIndex=-1>
<FONT face=Tahoma size=2><B>From:</B> Map Guy [mailto:mappington at yahoo.com] <BR><B>Sent:</B> Wednesday, March 03, 2004 12:21 PM<BR><B>To:</B> mapserver-users at lists.gis.umn.edu<BR><B>Subject:</B> [Mapserver-users] Distance Calculation<BR></FONT><BR></DIV>
<DIV></DIV>
<DIV>We use TIGER data for our mapping data source. We use a geographic projection (lat/lon). When we draw an 8 mile ring on a map with a 20 mile extent, and we plot a point and calculate the distance from the center using Great Circle we get 7.5 miles. Using a Cartesian calculation we get 8.2 miles. </DIV>
<DIV> </DIV>
<DIV>2 questions:</DIV>
<DIV> </DIV>
<DIV>1. Should we be seeing this much difference in distances?</DIV>
<DIV> </DIV>
<DIV>2. What is the correct way to draw a ring on a map using a geographic projection (lat/lon) and display distances between points using Great Circle without the distance placing the point incorrectly inside or outside the ring?</DIV>
<DIV> </DIV>
<DIV>Thanks in advance.</DIV>
<DIV> </DIV>
<DIV>P.S. Point me somewhere else if this is the wrong place to ask these questions.</DIV>
<P>
<HR SIZE=1>
Do you Yahoo!?<BR>Yahoo! Search - <A href="http://search.yahoo.com/?fr=ad-mailsig-home">Find what youre looking for faster.</A> </BLOCKQUOTE>
<P>
<HR SIZE=1>
<P>
<HR SIZE=1>
Do you Yahoo!?<BR>Yahoo! Search - <A href="http://search.yahoo.com/?fr=ad-mailsig-home">Find what youre looking for faster.</A> </BLOCKQUOTE></DIV>
<P>
<HR SIZE=1>
Do you Yahoo!?<BR>Yahoo! Search - <A href="http://search.yahoo.com/?fr=ad-mailsig-home">Find what youre looking for faster.</A> </BLOCKQUOTE><p><hr SIZE=1>
Do you Yahoo!?<br>
Yahoo! Search - <a href="http://search.yahoo.com/?fr=ad-mailsig-home">Find what youre looking for faster.</a>
--0-196938625-1078498710=:46912--
