[Mapserver-users] nightly compile error
Frank Warmerdam
warmerdam at pobox.com
Fri Mar 5 14:51:29 EST 2004
Randy James wrote:
> Hi
> I am trying to compile the nightly downloaded on march 5
> 2004 and am getting the following error. Does anyone
> reconize the error, or should i give more information?
> gcc -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ
> -DUSE_PROJ_API_H -DUSE_WMS_SVR -DUSE_GD_PNG
> -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL
> -DUSE_POSTGIS -I/usr/src/gd-2.0.15
> -I/usr/src/proj-4.4.5/src -I/usr/local/include
> -I/usr/local/pgsql/include shp2img.o -L. -lmap -ljpeg
> -lfreetype -lpng -lz -ljpeg -lfreetype -lpng -lz
> -L/usr/src/proj-4.4.5/src/.libs -lproj -ljpeg
> -L/usr/local/lib -lgdal.1.1 -L/usr/local/pgsql/lib -lpq
> -lm /usr/src/gd-2.0.15/.libs/libgd.a -o shp2img
> ./libmap.a(mapdrawgdal.o): In function
> `msDrawRasterLayerGDAL_RawMode':
> mapdrawgdal.o(.text+0x2afc): undefined reference to
> `GDALDatasetRasterIO'
> collect2: ld returned 1 exit status
> make: *** [shp2img] Error 1
Randy,
My error. GDALDatasetRasterIO() is a GDAL 1.2.0 feature - not available
in 1.1.9. I will correct the code to work for GDAL 1.1.9. In the meantime
you can update to GDAL 1.2.0 or comment out the call if you are in a hurry.
The call won't occur in normal MapServer use.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
