[Mapserver-users] Mapfile problem - polygon layer and labels
Sean Gillies
sgillies at frii.com
Sun Mar 7 10:33:47 EST 2004
On Mar 6, 2004, at 8:15 PM, Mike Reilly wrote:
> Hi:
> I've got a work around for the problem I'm having right now, however,
> it causes me to use two layers where I feel one would be more than
> adequate. I have a polygon layer called mergeplys, and in one layer
> declaration I only want to display the layers that contain "food
> harvest" in the "USE1" field. To this end, I built the following
> layers:
> LAYER # TUS polygon layer begins here
> NAME tusfoodharvest
> DATA "mergeplys"
> STATUS ON
> TYPE POLYGON
> TOLERANCE 3
> PROJECTION
> # "init=epsg:4326"
> END
> CLASSITEM "USE1"
> CLASS
> EXPRESSION "food harvest"
> TEMPLATE "templates/land_query.html"
> COLOR 100 255 100
> OUTLINECOLOR 0 255 0
> # LABEL
> # COLOR 0 0 0
> # TYPE TRUETYPE
> # FONT arial
> # SIZE 12
> # POSITION CC
> # PARTIALS FALSE
> # BUFFER 2
> # END
> END
> END # TUS polygon layer ends her
> LAYER
> NAME tusfoodharvest
> DATA "mergeplys"
> STATUS ON
> MAXSCALE 5000000000
> TYPE ANNOTATION
> LABELITEM "USE1"
> CLASSITEM "USE1"
> LABELMAXSCALE 500000000
> CLASS
> COLOR 0 0 0
> LABEL
> COLOR 0 0 0
> TYPE TRUETYPE
> FONT arial
> SIZE 12
> POSITION CC
> PARTIALS FALSE
> BUFFER 2
> END
> END
> END
> The first layer displays the polygon layer and the second one adds the
> label to the polygon. I would like to be able to combine these two
> into a single layer. My attempt at this is commented out in the
> POLYGON layer above. What am I missing here?
> On a separate note, I am creating a separate LAYER for each
> EXPRESSION. Is there a more efficient way to do this? My .map file
> is getting very large, and I suspect there's got to be a better way,
> however, I haven't devised one as yet.
> TIA,
> Mike Reilly
Mike,
I see right away that the first layer does not define a LABELITEM. That
may not be the _only_ problem, but you won't get a label without it.
Instead of a separate LAYER for each expression, use another CLASS.
CLASS
COLOR 100 255 100
END
CLASS
EXPRESSION "other expression"
COLOR 200 55 200
END
Hope this helps,
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
