[Mapserver-users] Error Displaying Rasters {Scanned}
Siki Zoltan
siki at agt.bme.hu
Mon Mar 8 04:21:41 EST 2004
Hi Sean,
I had similar problem on Linux with Mapserver 4.
I have recompiled Mapserver without tiff support.
On win32 I use the binary release, and it works fine.
I hope it helps you
Bye
Zoltan
On 7 Mar 2004, Sean Kleinjung wrote:
> Hello,
> We have been using an ancient version of MapServer (3.2) to run a number
> of websites. We are finally getting around to building a site using a
> new version (4.0.1) of MapServer, but have run into a snag getting
> raster data to display.
> We've upgraded our mapfiles and have gotten the query and display of
> ESRI shapefiles to work fine, but adding any raster layers to the
> mapfile causes the server to return an internal server error. I have
> tried both using tiled raster layers, and the simple case of just
> including a layer with the data pointing to an image file (as described
> in the Raster HOWTO).
> Enclosed at the end of this message is a stripped down mapfile with just
> a single raster layer. The .tif file I am referencing is a GeoTIFF and
> the supplied projection information is correct. It is an 8-bit image
> that displays fine under the systems running MapServer 3.2.
> The output of mapserv -v is as follows:
> MapServer version 4.0.1 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
> SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=TIFF INPUT=EPPL7
> INPUT=JPEG INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> and here is gdal-config --formats:
> gxf gtiff hfa aigrid aaigrid ceos ceos2 iso8211 bsb xpm sdts raw dted
> mem jdem envisat elas fit vrt usgsdem l1b nitf bmp jpeg2000 gif jpeg png
> Any hints as to what may be going wrong would be greatly appreciated.
> Thank you,
> Sean Kleinjung
> Web Application Developer
> Agri ImaGIS Technologies, Inc.
> sean at satshot.com
> Sample map file follows:
> # MapFile automatically generated by
> # Agri ImaGIS Technologies, Inc. jWebMap
> NAME "jWebMap-1078716933050"
> STATUS ON
> SIZE 400 400
> EXTENT 515000.0 5110000.0 840000.0 5440000.0
> IMAGECOLOR 255 255 255
> PROJECTION
> "proj=utm"
> "zone=14"
> "ellps=GRS80"
> END
> WEB
> TEMPLATE "/home/httpd/html/webmap/templates/1078716933035.html"
> END
> LAYER
> NAME "testRaster"
> TYPE RASTER
> STATUS DEFAULT
> DATA "/data/imagery/2003/L3026z14_Aug25_03.tif"
> PROJECTION
> "proj=utm"
> "zone=14"
> "ellps=GRS80"
> END
> END
> END
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
