[Mapserver-users] Non-8bit Raster Classification and NODATA
Frank Warmerdam
warmerdam at pobox.com
Mon Mar 8 13:02:53 EST 2004
Folks,
I have committed support for proper classification of non-8bit rasters in
MapServer. I hope to update the mapfile reference, and raster howto about
this soon, but the basics that non-8bit rasters are now supported for
a more refined classification (via a 16bit lookup table). Some notes:
o Only works via GDAL raster module.
o Only [pixel] can be used in expressions on these rasters, [red], [green]
and [blue] will be ignored.
o Internally mapserver is preparing a lookup table with up to 65536 entries
(buckets) so you still don't get complete accurancy when classifying floating
point values.
o For any 16bit integer rasters (signed or unsigned) classification results
should be exact.
o For floating point rasters scaling to the 16bit lookup table may be explicitly
controlled via the SCALE and SCALE_BUCKETS PROCESSING options. By default
scale min and max are computed from the data, and 65536 buckets are used.
o I have added support for a NODATA PROCESSING keyword so that non-colour
offsite values can be supported. These can't really be specified via the
OFFSITE keyword currently.
Anyone wanting to experiment with this will need to build from CVS (last
changes committed just a few minutes ago). Feel free to contact me for details.
There are also some contrived examples of the various options in the MSAutoTest
test suite.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
