[Mapserver-users] JBox with Mozilla 1.6, Load java applet faild
Shiming Li
sli1 at uni-forst.gwdg.de
Wed Mar 10 08:25:43 EST 2004
I tried to implement the zoom-box with the jBox, but it shows grey
color in the image area. There is a message showed in the status bar:
Loading Java Applet failed.
Following http://mapserver.gis.umn.edu/doc40/jbox-howto.html.
1) inserted
<SCRIPT LANGUAGE="JavaScript">
function setbox_handler(name, minx, miny, maxx, maxy) {
document.mapserv.imgbox.value = minx + " " + miny + " " + maxx
+ " " + maxy;
document.mapserv.imgxy.value = minx + " " + miny;
// Additional code can go here prior to the form submit, below.
// For example, form validation code.
document.mapserv.submit();
function seterror_handler(message) {
alert(message);
</SCRIPT>
2) change the line to <form method=GET action="[program]" name="mapserv">
inserted the line <input type="hidden" name="imgbox" value="-1 -1 -1 -1">
3) replace output map image defination with the following
<td align="center" colspan="2">
<applet
codebase="/usr/local/apache2/htdocs/titasca/java/mapplet/lib"
code="jBoxPNG.class"
archive="jBoxPNG.jar,png.jar"
width="600"
height="600"
name="jBoxPNG"
MAYSCRIPT>
<param name="image" value="http://[host][img]">
</applet>
</td> The directory of the lib and the jBox* files can be
accessable and executed by all persons.
I had installed the Java SDK 1.4.2, other information Mozilla 1.6, SuSE
linux, MapServer 4.01.
Is there something wrong?
Regards,
karl
