[Mapserver-users] shpxy
Steve Lime
steve.lime at dnr.state.mn.us
Wed Mar 10 14:45:54 EST 2004
Hi Paul: There's a [shpmid] tag (and maybe shpmidx/shpmidy tags) that
will give you a psuedo centroid. It's not a true centroid, but rather
the center of the bounding box. It was added originally as a means of
creating maps centered on a feature.
Out of curiousity why aren't polygons working for you? I assume the tag
works ok it's just not what you need to position an element.
We/I should extend the shpxy tag to simply replace the other [shp...]
tags. We could have different representations of a feature (default
full, bbox, center, centroid), plus support projections and feature
processing (e.g. line thinning).
Steve
>>> pagameba at magma.ca 3/9/2004 2:37:11 PM >>>
I'm using the [shpxy xf="," transform] in a template to create
imagemaps
... the imagemap onmouseover/onmouseout dynamically positions a dhtml
div element over the feature in the map. This works exceptionally well
for points but it doesn't work for polygons.
Is there anything I can use in a template to get a centroid value for a
polygon (rather than all the points)?
Also, has anyone tried to do this for lines? I'm using mapscript and
generating the template dynamically based the type of a selected layer.
Right now my approach is to get the points that make up lines and
then
create polygons by buffering the lines ... this is obviously quite a
lot
of work in php :)
Cheers,
Paul
|Paul Spencer spencer at dmsolutions.ca |
|Applications & Software Development |
|DM Solutions Group Inc http://www.dmsolutions.ca/|
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
