[Mapserver-users] scale is not correct
Pericles Nacionales
nacional at cbs.umn.edu
Thu Mar 11 17:48:30 EST 2004
It looks like your map is in geographic projection. You'll have to
reproject your data to some other grid-based projection if you want your
scale rendered properly. Here are some of the projections you might want
to have a look at:
http://www.geocities.com/CapeCanaveral/1224/prj/de/de.html
You'll need the proj library support to reproject your map on the fly, or
you can reproject your data using GIS tools and use that reprojected data
in MapServer.
Good luck!
-Perry N.
On Thu, 11 Mar 2004, Inna Janssen wrote:
> Hi,
> I have a strange problem with the scale:
> The scale is calculated wrong. In my map germany is just 8 meters long :-)
> (see it here: http://map.inna.de/mifazkarte/orte.php)
> But the scale is calculated absolutetely automatically? Is there any way
> to correct it?
> Inna
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
