RES: [Mapserver-users] Compiling mapserver 4 with gdal + ogr + wfs suport
Sandro Danilo Gatti
Gatti at cpqd.com.br
Fri Mar 12 08:39:49 EST 2004
Hello
now I get the following :
$ ./configure --with-proj --with-gdal --with-ogr=/usr/local/bin/gdal-config --with-wmsclient --with-wfsclient --with-wsm --with-wfs
checking whether we should include OGR support...
checking for OGRRegisterAll in -lgdal.1.1... (cached) no
configure: warning: OGR not found in system libs... use --with-ogr=DIR.
checking if GDAL support requested... yes
checking if PostGIS support requested... no
checking if MyGIS support requested... no
checking if OracleSpatial support requested... no
checking if MING/Flash support requested... no
checking whether we should include WMS Server support...
OGC WMS compatibility enabled (-DUSE_WMS_SVR).
checking whether we should include WFS Server support...
configure: error: OGC WFS Server support cannot be enabled: missing OGR which is required).
my gdal is configured as follows :
$ /usr/local/bin/gdal-config --libs
-L/usr/local/lib -lgdal
$ /usr/local/bin/gdal-config --ogr-enabled
yes
$ /usr/local/bin/gdal-config --formats
gxf gtiff hfa aigrid aaigrid ceos ceos2 iso8211 xpm sdts raw dted mem jdem envisat elas fit vrt usgsdem l1b nitf bmp pcidsk bsb gif jpeg png
Have I made any mistake compiling gdal? I don't know if it has something to with it, but I have not installed LibGeoTiff and LibTiff suport. Does OGR need them?
Thank you
Sandro Danilo Gatti
Analista de Sistemas
CPqD Telecom & IT Solutions
Tel.: +55 19 3705-4420
gatti at cpqd.com.br
http://www.cpqd.com.br
|- Sandro Danilo Gatti wrote:
|- > Hello!
|- > I'm trying to build mapserver 4.0 with WFS suport and so
|- I've been using the following configure parameters (well,
|- I've also tried other configuration parameters, but they
|- turned out the same) :
|- > $ ./configure --with-proj --with-gdal
|- --with-ogr=/usr/local/bin/ --with-wmsclient --with-wfsclient
|- --with-wsm --with-wfs
|- Try using --with-ogr=/usr/local/bin/gdal-config
|- Daniel
|- Daniel Morissette dmorissette at dmsolutions.ca
|- DM Solutions Group http://www.dmsolutions.ca/
