[Mapserver-users] Internal Server Error / How can I check for
errors?
Dylan Keon
keon at nacse.org
Sun Mar 14 17:53:55 EST 2004
Andreas,
Send along your mapfile and the output of 'mapserv -v'.
Andreas Delleske wrote:
> Hi there,
> this is my second attempt to get an answer, although browsing through the docs and google didnt help till now:
> I have a 4.0.1 mapserver running (besides the problem) fine on a debian sarge installation.
> The only thing is that if tiff-images (for input) are involved, apache says "internal server error (500)" and the logfiles say nothing. This although the same tiff-maps worked fine on another installation of mapserver 3.6.5 on SUSE...
> I assume the libraries must be in limbo...
> How can I check whether everything is linked fine? How are the memory limitations? (This could be another possible source of trouble)
> ldd mapserv gives:
> libgd.so.2 => /usr/lib/libgd.so.2 (0x4001d000)
> libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0x40056000)
> libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0x40074000)
> libpng12.so.0 => /usr/lib/libpng12.so.0 (0x400e2000)
> libz.so.1 => /usr/lib/libz.so.1 (0x40106000)
> libtiff.so.3 => /usr/lib/libtiff.so.3 (0x40117000)
> libproj.so.0 => /usr/lib/libproj.so.0 (0x4015a000)
> libgdal.so.1 => /usr/lib/libgdal.so.1 (0x4018c000)
> libcurl.so.2 => /usr/lib/libcurl.so.2 (0x4051d000)
> libssl.so.0.9.6 => /usr/lib/i686/cmov/libssl.so.0.9.6 (0x40549000)
> libcrypto.so.0.9.6 => /usr/lib/i686/cmov/libcrypto.so.0.9.6 (0x40576000)
> libdl.so.2 => /lib/libdl.so.2 (0x4062e000)
> libm.so.6 => /lib/libm.so.6 (0x40631000)
> libc.so.6 => /lib/libc.so.6 (0x40653000)
> libpthread.so.0 => /lib/libpthread.so.0 (0x40786000)
> libXpm.so.4 => /usr/X11R6/lib/libXpm.so.4 (0x407d8000)
> libX11.so.6 => /usr/X11R6/lib/libX11.so.6 (0x407e7000)
> libodbc.so.1 => /usr/lib/libodbc.so.1 (0x408ae000)
> libxerces-c.so.21 => /usr/lib/libxerces-c.so.21 (0x40926000)
> libmfhdf.so.4 => /usr/lib/libmfhdf.so.4 (0x40cee000)
> libdf.so.4 => /usr/lib/libdf.so.4 (0x40d10000)
> libungif.so.4 => /usr/lib/libungif.so.4 (0x40db0000)
> libcfitsio.so.2 => /usr/lib/libcfitsio.so.2 (0x40db8000)
> libstdc++-libc6.2-2.so.3 => /usr/lib/libstdc++-libc6.2-2.so.3 (0x40ef9000)
> libssl.so.0.9.7 => /usr/lib/i686/cmov/libssl.so.0.9.7 (0x40f42000)
> libcrypto.so.0.9.7 => /usr/lib/i686/cmov/libcrypto.so.0.9.7 (0x40f71000)
> /lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x40000000)
> libltdl.so.3 => /usr/lib/libltdl.so.3 (0x41063000)
> PNG, freetype goes well already.
> Any hints? How can I debug such a case if no logfile output is generated?
