[Mapserver-users] Internal Server Error / How can I check for
errors? {Scanned} {Scanned}
Siki Zoltan
siki at agt.bme.hu
Mon Mar 15 06:05:10 EST 2004
Try to rebuild mapserver without tiff, but with gdal.
gdal can handle tiffs.
It helped me on RedHat 9.
Bye
Zoltan
On Sun, 14 Mar 2004, Andreas Delleske wrote:
> Hi there,
> this is my second attempt to get an answer, although browsing through the docs and google didnt help till now:
> I have a 4.0.1 mapserver running (besides the problem) fine on a debian sarge installation.
> The only thing is that if tiff-images (for input) are involved, apache says "internal server error (500)" and the logfiles say nothing. This although the same tiff-maps worked fine on another installation of mapserver 3.6.5 on SUSE...
> I assume the libraries must be in limbo...
> How can I check whether everything is linked fine? How are the memory limitations? (This could be another possible source of trouble)
> ldd mapserv gives:
> libgd.so.2 => /usr/lib/libgd.so.2 (0x4001d000)
> libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0x40056000)
> libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0x40074000)
> libpng12.so.0 => /usr/lib/libpng12.so.0 (0x400e2000)
> libz.so.1 => /usr/lib/libz.so.1 (0x40106000)
> libtiff.so.3 => /usr/lib/libtiff.so.3 (0x40117000)
> libproj.so.0 => /usr/lib/libproj.so.0 (0x4015a000)
> libgdal.so.1 => /usr/lib/libgdal.so.1 (0x4018c000)
> libcurl.so.2 => /usr/lib/libcurl.so.2 (0x4051d000)
> libssl.so.0.9.6 => /usr/lib/i686/cmov/libssl.so.0.9.6 (0x40549000)
> libcrypto.so.0.9.6 => /usr/lib/i686/cmov/libcrypto.so.0.9.6 (0x40576000)
> libdl.so.2 => /lib/libdl.so.2 (0x4062e000)
> libm.so.6 => /lib/libm.so.6 (0x40631000)
> libc.so.6 => /lib/libc.so.6 (0x40653000)
> libpthread.so.0 => /lib/libpthread.so.0 (0x40786000)
> libXpm.so.4 => /usr/X11R6/lib/libXpm.so.4 (0x407d8000)
> libX11.so.6 => /usr/X11R6/lib/libX11.so.6 (0x407e7000)
> libodbc.so.1 => /usr/lib/libodbc.so.1 (0x408ae000)
> libxerces-c.so.21 => /usr/lib/libxerces-c.so.21 (0x40926000)
> libmfhdf.so.4 => /usr/lib/libmfhdf.so.4 (0x40cee000)
> libdf.so.4 => /usr/lib/libdf.so.4 (0x40d10000)
> libungif.so.4 => /usr/lib/libungif.so.4 (0x40db0000)
> libcfitsio.so.2 => /usr/lib/libcfitsio.so.2 (0x40db8000)
> libstdc++-libc6.2-2.so.3 => /usr/lib/libstdc++-libc6.2-2.so.3 (0x40ef9000)
> libssl.so.0.9.7 => /usr/lib/i686/cmov/libssl.so.0.9.7 (0x40f42000)
> libcrypto.so.0.9.7 => /usr/lib/i686/cmov/libcrypto.so.0.9.7 (0x40f71000)
> /lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x40000000)
> libltdl.so.3 => /usr/lib/libltdl.so.3 (0x41063000)
> PNG, freetype goes well already.
> Any hints? How can I debug such a case if no logfile output is generated?
