[Mapserver-users] PHP/Mapscript -- Help doing queries
Vinko Vrsalovic
vinko at cprsig.cl
Mon Mar 15 11:02:11 EST 2004
This snippet gives you an array ($result) with the shapes found for each
layer.
>From here you should be able to add what you need, for instance, through
$lyr->data and $cmo->shapeindex...
@$map->queryByRect($pt);
for ($i=0;$i<$map->numlayers;$i++) {
@$lyr = $map->getLayer($i);
if ($lyr->type == MS_LAYER_POLYGON || $lyr->type == MS_LAYER_POINT || $lyr->type == MS_LAYER_LINE) {
$lyr->open();
for ($j=0;$j<$lyr->getNumResults();$j++) {
$cmo = $lyr->getResult($j);
$shp = $lyr->getShape($cmo->tileindex,$cmo->shapeindex);
$result[$lyr->name][$j] = $shp;
$lyr->close();
On Sun, Mar 14, 2004 at 09:49:16AM -0500, Ed Martin wrote:
> this is my first time doing queries with mapscript and i'm having some
> problems, first i can't find any way that i can just put the shape
> indexes of the results into an array along with the NAME value of the
> dbf file, so since i can't do that i decided i would try to use a
> template and then maybe i'll read the results from the template and put
> into an array, but i can't get the template working, i get no errors at
> all but it returns nothing, not even the static information in the
> template, so i changed the template file to the php file i was working
> on, and it worked but i can't use the php file as template, and the two
> files have the same permissions and are in the same folder
> so how can i get the templates working or preferably skip the template
> and put the info i need into an array, please help
> here is the template i'm trying to use
> <tr>
> <td>
> <a href="index.phtml?shp=[shpidx]">[NAME]</a>
> </td>
> </tr>
> here is the php that i'm using
> dl("php_mapscript.so");
> $map = ms_newMapObj("map/map.map");
> //zoom/pan the
> $extent_to_set = explode(" ",$_SESSION['extent_old']);
> $map->setextent($extent_to_set[0],$extent_to_set[1],
> $extent_to_set[2],$extent_to_set[3]);
> //calculate the coords
> $x_click =
> ($_POST['mapa_x']/$map->width*($extent_to_set[2]-
> $extent_to_set[0]))+$extent_to_set[0];
> $y_click =
> ($_POST['mapa_y']/$map->height*($extent_to_set[3]-
> $extent_to_set[1]))+$extent_to_set[1];
> $cities_layer = $map->getLayerByName('Cities');
> $point_obj = ms_newPointObj();
> $point_obj->setXY($x_click,$y_click);
> $query_tf =
> @$cities_layer->queryByPoint($point_obj,MS_MULTIPLE,-1);
> if ($query_tf == MS_SUCCESS){
> echo 'Query worked<br />';
> echo $cities_layer->getNumResults().' places found';
> $query = $map->processquerytemplate('',FALSE);
> echo "<table>$query</table>";
> } else {
> echo 'Query Failed';
> and here is a bit of the map file
> LAYER
> NAME "Cities"
> TYPE POINT
> STATUS default
> DATA
> "/usr/local/apache/htdocs/adsbytown/site/mapserver/map/data/ci10de03"
> LABELMAXSCALE 1025400
> LABELITEM "NAME"
> MAXSCALE 4101800
> LABELCACHE on
> TOLERANCE 25
> TOLERANCEUNITS miles
> METADATA
> "title" "Title"
> "author" "Me!"
> END
> CLASS
> TEMPLATE
> /usr/local/apache/htdocs/adsbytown/site/mapserver/query.tpl
> #php file i used was
> /usr/local/apache/htdocs/adsbytown/site/mapserver/index.phtml
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Vinko Vrsalovic <el[|- at -|]vinko.cl>
http://www.cprsig.cl
