[Mapserver-users] virtual layers befor map file layers
Homme Zwaagstra
hrz at geodata.soton.ac.uk
Wed Mar 17 05:00:40 EST 2004
You can alter the drawing order of layers in the map object using the
following methods of the map object:
setlayersdrawingorder(layersindex:array)
moveLayerUp(layerindex:int)
moveLayerDown(layerindex:int)
See also getlayersdrawingorder()
Kind regards,
Homme Zwaagstra
On Tue, Mar 16, 2004 at 02:37:27PM +0100, Gijs Epping wrote:
> Hello,
> I added some virtual layers, but before i do, i add the map file with
> his own layers (some point data). The problem is that the POINT layers
> are added before the RASTER layers and so you don't see them because
> they are behind the rasters.
> How can you reverse this or change the index of the map layers or
> dynamic layers.
> Thanks in advance
> Gijs
