[Mapserver-users] WMS error EPSG:32633
Homme Zwaagstra
hrz at geodata.soton.ac.uk
Wed Mar 17 05:32:53 EST 2004
The only thing I can think of is that the line:
"WMS_SRS" "EPSG:4326 EPSG:32633"
in your WEB object is not necessary; the WMS Server HOWTO at
http://mapserver.gis.umn.edu/doc40/wms-server-howto.html#mapfile
states that the WMS_SRS is "optional since the layers inherit the map's
SRS value"
If this doesn't help then it would be worth submitting a bug report.
Kind regards,
Homme Zwaagstra
On Tue, Mar 16, 2004 at 02:58:37PM +0100, snow 77 wrote:
> Hi,
> Can anyone tell me what I do wrong?
> I'd like to use WMS with the following http-request:
> http://localhost/cgi-bin/mapserv.exe?map=C:/inetpub/wwwroot/demo/test2.map&WMTVER=1.0.0&REQUEST=map&BBOX=393042,5147575,583042,5313825&WIDTH=400&HEIGHT=350&LAYERS=aut6__________a7&FORMAT=image/png&SRS=EPSG:32633
> When I do that, I get an error from mapserv.exe (read error on the memory).
> If I use EPSG:4326 everything works fine but my image (map) is quite
> distorted. The shapefiles are epsg:4326 and the output should be epsg:32633.
> May I have an error in my mapfile?
> MAP
> NAME "test"
> STATUS ON
> #EXTENT 13.563817 46.2695106622074 16.166907714098 48.1749556
> EXTENT 389334.69 5124995.01 586750.69 5336404.45
> SIZE 400 350
> SHAPEPATH "../../../Inetpub/wwwroot/demo/data"
> FONTSET "../../../Inetpub/wwwroot/demo/fonts/fonts.list"
> IMAGECOLOR 255 255 255
> #UNITS DD
> UNITS METERS
> RESOLUTION 72
> PROJECTION
> "init=epsg:32633"
> END
> WEB
> TEMPLATE demo.html
> MINSCALE 1000
> MAXSCALE 1550000
> IMAGEPATH "set in demo_init.html"
> IMAGEURL "set in demo_init.html"
> METADATA
> "WMS_TITLE" "JRS Mapserver Demo"
> "WMS_ABSTRACT" "This is the JRS MapServer demonstration application for
> Styria located in central Austria."
> "WMS_ACCESSCONSTRAINTS" none
> "WMS_ONLINERESOURCE"
> "http://localhost/cgi-bin/mapserv.exe?map=c:/inetpub/wwwroot/demo/test2.map&"
> END
> END
> LAYER
> NAME "aut6__________a7"
> STATUS ON
> PROJECTION
> "init=epsg:4326"
> END
> DATA "../../../../Inetpub/wwwroot/demo/data/aut6__________a7"
> LABELITEM "NAME"
> CLASS
> TEMPLATE void
> COLOR 255 255 204
> OUTLINECOLOR 200 200 200
> LABEL
> COLOR 132 31 31
> COLOR 16 125 65
> TYPE TRUETYPE
> FONT arial-bold
> SIZE 10
> ANTIALIAS TRUE
> POSITION AUTO
> PARTIALS FALSE
> MINDISTANCE 300
> BUFFER 4
> END # end of label
> END
> TYPE POLYGON
> METADATA
> "WMS_TITLE" "aut6__________a7"
> "WMS_SRS" "EPSG:4326"
> END
> END
> END
> I think I have read all documentations due to this problem, but I can't
> find a solution. I have used the same mapfile with the template "demo.html"
> and it works perfect. But mapserver crashes when I try to use it as WMS.
> Can anyone help me?
> Many thanks in advance!
> Sonja
> _________________________________________________________________
> Die MSN Suche - Kategorien helfen Ihnen dabei, pr?zise Ergebnisse zu
> erhalten. http://search.msn.at/
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
