[Mapserver-users] Draw circle with polygon
Gijs Epping
gijs at gijs.com
Wed Mar 17 08:18:14 EST 2004
This is a multi-part message in MIME format.
------=_NextPart_000_0001_01C40C2A.AFCC5460
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: 7bit
Hello,
I am trying to draw a circle that has to scale with the map, I have some
code now (see below) but that doesn't do the trick it just shows a
circle that doesn't scale with the map (It just stay's the same width if
I set a different extension).
I think i need to create a polygon that is connected to a point, but I
don't know how at the moment if somebody could give me a push in the
right direction it would be great.
Thanks in advance
Gijs
function createPoint( $x, $y, $programId )
GLOBAL $shpFile, $dbfFile;
// Create shape
$oShp = ms_newShapeObj(MS_SHAPE_POINT);
$oLine = ms_newLineObj();
$oLine->addXY($x, $y);
$oShp->add($oLine);
$shpFile->addShape($oShp); // Write attribute record
dbase_add_record($dbfFile, array($programId));
$shpFname = "/var/www/html/atmsv03/proximity";
$shpFile = ms_newShapeFileObj($shpFname, MS_SHP_POINT);
$dbfFile = dbase_create( $shpFname.".dbf", array(array("ID", "N", 5,
0)));
createPoint($punt[0], $punt[1], 1); // the points come from an area
code point
$shpFile->free();
dbase_close($dbfFile);
// Set the buffer distance
$pt_layer = $map->getLayerByName("proximity");
$pt_layer->set("status", MS_ON);
$pt_class = $pt_layer->getclass(0);
The map file part:
LAYER
NAME "proximity"
data proximity
STATUS off
TYPE POINT
SIZEUNITS meters
TRANSPARENCY 50
CLASS
SIZE 1000
NAME 'transcircle'
SYMBOL 'transcircle'
COLOR 255 0 0
END
END
SYMBOL
NAME 'transcircle'
TYPE ELLIPSE
POINTS 1 1
END
FILLED TRUE
END
Content-Type: text/html;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C40C2A.ADA0C1D0">
<!--[if gte mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:SpellingState>Clean</w:SpellingState>
<w:GrammarState>Clean</w:GrammarState>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:HyphenationZone>21</w:HyphenationZone>
<w:EnvelopeVis/>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
</xml><![endif]-->
<style>
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0cm;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
p.MsoAutoSig, li.MsoAutoSig, div.MsoAutoSig
{margin:0cm;
font-size:12.0pt;
span.EmailStijl18
{mso-style-type:personal-compose;
mso-style-noshow:yes;
mso-ansi-font-size:10.0pt;
mso-bidi-font-size:10.0pt;
font-family:Arial;
mso-ascii-font-family:Arial;
mso-hansi-font-family:Arial;
mso-bidi-font-family:Arial;
color:windowtext;}
span.SpellE
{mso-style-name:"";
mso-spl-e:yes;}
@page Section1
{size:612.0pt 792.0pt;
margin:70.85pt 70.85pt 70.85pt 70.85pt;
mso-header-margin:35.4pt;
mso-footer-margin:35.4pt;
mso-paper-source:0;}
div.Section1
{page:Section1;}
</style>
<!--[if gte mso 10]>
<style>
/* Style Definitions */=20
table.MsoNormalTable
{mso-style-name:Standaardtabel;
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
font-size:10.0pt;
</style>
<![endif]-->
</head>
<body lang=3DNL link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:35.4pt'>
<div class=3DSection1>
<p class=3DMsoNormal =
style=3D'mso-layout-grid-align:none;text-autospace:none'><font
size=3D2 face=3D"Courier New"><span lang=3DEN-GB =
style=3D'font-size:10.0pt;font-family:
"Courier =
New";mso-ansi-language:EN-GB'>Hello,<o:p></o:p></span></font></p>
"Courier =
New";mso-ansi-language:EN-GB'><o:p> </o:p></span></font></p>
"Courier New";mso-ansi-language:EN-GB'>I am trying to draw a circle that =
has to
scale with the map, I have some code now (see below) but that =
doesn’t do
the trick it just shows a circle that doesn't scale with the map (It =
just
stay's the same width if I set a different extension). =
"Courier =
"Courier New";mso-ansi-language:EN-GB'>I think i need to create a =
polygon that
is connected to a point, but I don’t know how at the moment if =
somebody
could give me a push in the right direction it would be =
great.<o:p></o:p></span></font></p>
"Courier =
"Courier New";mso-ansi-language:EN-GB'>Thanks in =
advance<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:EN-GB'>Gijs<o:p></o:p></span></font></p>
"Courier =
"Courier =
"Courier New";mso-ansi-language:EN-GB'>function createPoint( $x, $y, =
$programId
)<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:EN-GB'><span
style=3D'mso-spacerun:yes'> =
</span>{<o:p></o:p></span></font></p>
style=3D'mso-spacerun:yes'> </span>GLOBAL =
$shpFile,
$dbfFile;<o:p></o:p></span></font></p>
"Courier =
style=3D'mso-spacerun:yes'> </span>// =
Create shape<o:p></o:p></span></font></p>
style=3D'mso-spacerun:yes'> </span>$oShp =
=3D
ms_newShapeObj(MS_SHAPE_POINT);<o:p></o:p></span></font></p>
style=3D'mso-spacerun:yes'> </span>$oLine =
=3D
ms_newLineObj();<o:p></o:p></span></font></p>
</span>$oLine->addXY($x, $y);<o:p></o:p></span></font></p>
</span>$oShp->add($oLine);<o:p></o:p></span></font></p>
</span>$shpFile->addShape($oShp); // Write attribute =
record<o:p></o:p></span></font></p>
</span>dbase_add_record($dbfFile, =
array($programId));<o:p></o:p></span></font></p>
</span>}<o:p></o:p></span></font></p>
"Courier =
style=3D'mso-spacerun:yes'> </span>$shpFname =3D
"/var/www/html/atmsv03/proximity";<o:p></o:p></span></font></p>=
style=3D'mso-spacerun:yes'> </span>$shpFile =3D
ms_newShapeFileObj($shpFname, =
MS_SHP_POINT);<o:p></o:p></span></font></p>
style=3D'mso-spacerun:yes'> </span>$dbfFile =3D =
dbase_create(
$shpFname.".dbf", array(array("ID", "N", =
5, 0)));<o:p></o:p></span></font></p>
"Courier =
style=3D'mso-spacerun:yes'> </span>createPoint($punt[0], =
$punt[1],
1); // the points come from an area code =
point<o:p></o:p></span></font></p>
"Courier =
</span>$shpFile->free();<o:p></o:p></span></font></p>
</span>dbase_close($dbfFile);<o:p></o:p></span></font></p>
"Courier =
style=3D'mso-spacerun:yes'> </span>// Set the buffer =
distance<o:p></o:p></span></font></p>
style=3D'mso-spacerun:yes'> </span>$<span =
class=3DSpellE>pt_layer</span>
=3D =
$map->getLayerByName("proximity");<o:p></o:p></span></font><=
/p>
</span>$pt_layer->set("status", =
MS_ON);<o:p></o:p></span></font></p>
style=3D'mso-spacerun:yes'> </span>$pt_class =3D
$pt_layer->getclass(0);<o:p></o:p></span></font></p>
"Courier =
"Courier =
"Courier =
"Courier =
"Courier New";mso-ansi-language:EN-GB'>The map file =
part:<o:p></o:p></span></font></p>
"Courier =
"Courier =
New";mso-ansi-language:EN-GB'>LAYER<o:p></o:p></span></font></p>
style=3D'mso-spacerun:yes'> </span>NAME =
"proximity"<o:p></o:p></span></font></p>
style=3D'mso-spacerun:yes'> </span>data =
proximity<o:p></o:p></span></font></p>
style=3D'mso-spacerun:yes'> </span>STATUS =
off<o:p></o:p></span></font></p>
style=3D'mso-spacerun:yes'> </span>TYPE =
POINT<o:p></o:p></span></font></p>
style=3D'mso-spacerun:yes'> </span>SIZEUNITS =
meters<o:p></o:p></span></font></p>
style=3D'mso-spacerun:yes'> </span>TRANSPARENCY =
50<o:p></o:p></span></font></p>
"Courier =
New";mso-ansi-language:EN-GB'>CLASS<o:p></o:p></span></font></p>
style=3D'mso-spacerun:yes'> </span>SIZE =
1000<o:p></o:p></span></font></p>
'transcircle'<o:p></o:p></span></font></p>
style=3D'mso-spacerun:yes'> </span>SYMBOL =
style=3D'mso-spacerun:yes'> </span>COLOR 255 0 =
style=3D'mso-spacerun:yes'> </span>END<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:EN-GB'>END<o:p></o:p></span></font></p>
"Courier =
New";mso-ansi-language:EN-GB'>SYMBOL<o:p></o:p></span></font></p>
ELLIPSE<o:p></o:p></span></font></p>
style=3D'mso-spacerun:yes'> </span></span></font><font size=3D2
face=3D"Courier New"><span =
style=3D'font-size:10.0pt;font-family:"Courier New"'>POINTS
1 <span class=3DSpellE>1</span><o:p></o:p></span></font></p>
size=3D2 face=3D"Courier New"><span =
style=3D'font-size:10.0pt;font-family:"Courier New"'><span
style=3D'mso-spacerun:yes'> </span>FILLED =
TRUE<o:p></o:p></span></font></p>
style=3D'font-size:10.0pt;font-family:"Courier =
New"'>END<o:p></o:p></span></font></p>
New"'><o:p> </o:p></span></font></p>
<p class=3DMsoNormal><font size=3D3 face=3D"Times New Roman"><span =
style=3D'font-size:
12.0pt'><o:p> </o:p></span></font></p>
</div>
</body>
</html>
------=_NextPart_000_0001_01C40C2A.AFCC5460--
