[Mapserver-users] Rendering mapscript style modifications
Wheaton, William D.
wdw at rti.org
Wed Mar 17 15:09:40 EST 2004
Hello all:
I'm having a basic conceptual problem understanding the interaction between
the modification of a layer in php/mapscript and then rendering those
modifications...I've searched far and wide in the e-mail archives, but I
guess I'm just missing some basic concept here.
Given a .map file with several layers, then:
1) $map = ms_newMapObj(file.map);
For the layer I want to change, the .map file looks like this:
LAYER
PROJECTION
"proj=latlong"
"ellps=clrk66"
END
CONNECTIONTYPE postgis
NAME "Respondents"
GROUP "Base Data"
CONNECTION "user=xxxx dbname=xxx password=xxxx"
DATA "the_geom from resp"
STATUS DEFAULT
TYPE POINT
METADATA
LYRNAME "Respondents"
END
CLASS
STYLE
COLOR 255 0 0
END
END
END
2) Then, through php/mapscript, grab this layer and change its style:
$layer=$map->getlayerbyname('Respondents');
3) Modify the style of this layer:
$class=ms_newClassObj($layer);
$style=ms_newStyleObj($class);
$style->color->setRGB(0,255,0);
$class->set("status", MS_ON);
$layer->set("status", MS_ON);
$image=$map->draw();
$image_url=$image->saveWebImage(MS_PNG,1,1,0);
4) With this, the map gets drawn with the layer symbology as specified in
the .map file, not with the modifications made above in the mapscript...
So, I have a basic problem understanding how modifications to a layer in a
mapscript file get rendered on the map...Is it order? Am I missing a
something?
Many thanks in advance for any help. I'm at my wits end!
