[Mapserver-users] Rendering mapscript style modifications
Wheaton, William D.
wdw at rti.org
Wed Mar 17 16:43:34 EST 2004
Eric--
Thanks for the response and suggestion. Unfortunately, no joy.
I've now tried:
$image=$map->prepareImage();
$layer->draw($map, $image);
$image=$map->draw();
$image_url=$image->saveWebImage(MS_PNG,1,1,0);
And:
In both cases, I get this error:
Fatal error: Object has an invalid _handle_ property in
/var/www/htdocs/els/mapscript_test.phtml on line 43
The error refers to the $layer->draw($map, $image) line...Is that an error
that helps decipher the problem? I searched the list and didn't find
anything on that error...Many thanks for helping out!
Bill.
-----Original Message-----
Sent: Wednesday, March 17, 2004 4:15 PM
To: Wheaton, William D.
Cc: 'mapserver-users at lists.gis.umn.edu'
Subject: Re: [Mapserver-users] Rendering mapscript style modifications
William,
I remember going thru the same conceptual confusion when I first started
with mapscript. I use Perl mapscript but the issues are the same. I don't
have the time to check the docs so take the following with a grain of salt.
The fundemental difference is: mapscript methods which take an Image object
and those that don't.
I believe that the call to $map->draw() takes care of "preparing" the GD
image for drawing and then draws all the layers in the map file.
You should switch to using:
$img = $map->prepareImage()
And then using the draw methods which take an $img paramter. E.g.
$layer->draw($map, $img).
It may be, that you could use $img = $map->draw() and then use
$layer->draw($map, $img) afterwards. That might work.
My method requires a lot more work, in the sense of getting all the layers
in the map file and drawing them one by one.
HTH
Eric
On Wed, 2004-03-17 at 15:09, Wheaton, William D. wrote:
> Hello all:
> I'm having a basic conceptual problem understanding the interaction
> between the modification of a layer in php/mapscript and then
> rendering those modifications...I've searched far and wide in the
> e-mail archives, but I guess I'm just missing some basic concept here.
> Given a .map file with several layers, then:
> 1) $map = ms_newMapObj(file.map);
> For the layer I want to change, the .map file looks like this: LAYER
> PROJECTION
> "proj=latlong"
> "ellps=clrk66"
> END
> CONNECTIONTYPE postgis
> NAME "Respondents"
> GROUP "Base Data"
> CONNECTION "user=xxxx dbname=xxx password=xxxx"
> DATA "the_geom from resp"
> STATUS DEFAULT
> TYPE POINT
> METADATA
> LYRNAME "Respondents"
> END
> CLASS
> STYLE
> COLOR 255 0 0
> END
> END
> END
> 2) Then, through php/mapscript, grab this layer and change its style:
> $layer=$map->getlayerbyname('Respondents');
> 3) Modify the style of this layer:
> $class=ms_newClassObj($layer);
> $style=ms_newStyleObj($class); $style->color->setRGB(0,255,0);
> $class->set("status", MS_ON);
> $layer->set("status", MS_ON);
> 4) With this, the map gets drawn with the layer symbology as specified
> in the .map file, not with the modifications made above in the
> mapscript...
> So, I have a basic problem understanding how modifications to a layer
> in a mapscript file get rendered on the map...Is it order? Am I
> missing a something?
> Many thanks in advance for any help. I'm at my wits end!
> Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
