[Mapserver-users] Just call me a newbie . . . multiple Raster LAYERs question
Sean Gillies
sgillies at frii.com
Wed Mar 17 18:26:47 EST 2004
On Mar 17, 2004, at 4:12 PM, Bob Basques wrote:
> All,
> Let's say I have Six different levels of resolution of Aerial Photo's
> all of them having the same coverage extents.
> Can I use different source data (a different tileindex for each of the
> levels above) for different classifications of the LAYER?
> Like the following, which is the coursest layer at 16 feet per pixel:
> # Start of map file
> MAP
> NAME CITIPIX
> STATUS ON
> SIZE 600 600
> EXTENT 540000 135000 600000 175000
> UNITS FEET
> SHAPEPATH "./data"
> IMAGECOLOR 255 255 255
> IMAGETYPE JPEG
> LAYER
> NAME "AERIALS"
> STATUS DEFAULT
> TILEINDEX "RAST_STPL_PW_AER_SUR_2001_06_L5"
> TILEITEM "Location"
> TYPE RASTER
> END
> END # Map File
> I have five other TILEINDEXes,
> RAST_STPL_PW_AER_SUR_2001_06_L4 = 8 feet per pixel
> RAST_STPL_PW_AER_SUR_2001_06_L3 = 4
> RAST_STPL_PW_AER_SUR_2001_06_L2 = 2
> RAST_STPL_PW_AER_SUR_2001_06_L1 = 1
> RAST_STPL_PW_AER_SUR_2001_06_L0 = 0.5
> Do I need to make a layer for each tile index, or can they all be
> sourced under the same LAYER definition (aerials)? There will only
> ever be one of them at a time visible. So can the layer look like
> this (or some close)?
> LAYER
> NAME "AERIALS"
> STATUS DEFAULT
> class [pixel]
> classitem ( [pixel] >= 16 ) ## what does "pixel" represent
> anyway? It's not clear to me from the HowTo
> classitem ([pixel} >= 8 )
> TILEINDEX "RAST_STPL_PW_AER_SUR_2001_06_L4"
> classitem ([pixel} >= 4 )
> TILEINDEX "RAST_STPL_PW_AER_SUR_2001_06_L3"
> classitem ([pixel} >= 2 )
> TILEINDEX "RAST_STPL_PW_AER_SUR_2001_06_L2"
> classitem ([pixel} >= 1 )
> TILEINDEX "RAST_STPL_PW_AER_SUR_2001_06_L1"
> classitem ([pixel} >= 0.5 )
> TILEINDEX "RAST_STPL_PW_AER_SUR_2001_06_L0"
> TILEITEM "Location"
> TYPE RASTER
> END
> or do I need to class them each as seperate layers in the map file
> with a max/min specification?
> Thanks
> bobb
Separate layer for each, but use the same GROUP for all so you can turn
the
collection on/off together.
LAYER
NAME "16F"
GROUP "AERIAL"
MINSCALE 100000
END
LAYER
NAME "8F"
GROUP "AERIAL"
MAXSCALE 100000
MINSCALE 50000
END
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
