[Mapserver-users] Unable to display data stored in Oracle Spatial
Fortin,Nicolas [SteFoy]
nicolas.fortin at ec.gc.ca
Thu Mar 18 07:46:31 EST 2004
Hi Jiri,
Always forward to the list to have better chance of answer...
For what I'va seen for now with my data, Oracle layers need a SRID set in the SDO table and in the DATA element (USING SRID XXXXX). I can't help you more for this cause I'm not the one who deal with Oracle spatial here but we also have a Coord Syst that was not in the mdsys.cs_srs (custom LCC) and our spatial guy add manually the SRID to the table (see my example in previous mail with SRID=3000000 and the custom LCC definition).
You can also try to set a PROJECTION for the map too.
Regards,
Nicolas
-----Message d'origine-----
De : Jiri Potocny [mailto:potocny at espace.cz]
Envoyé : Thursday, March 18, 2004 7:28 AM
À : Fortin,Nicolas [SteFoy]
Objet : Re: [Mapserver-users] Unable to display data stored in Oracle Spatial
Nicolas
thank you for your advice.
I was unable to find appropriate coordinate system in mdsys.cs_srs, so all features in MDSYS.SDO_GEOM_METADATA_TABLE have SR_ID set to Null.
I tryed to define PROJECTION by parameters or through "init=epsg:4818", but the result is still the same. See the mapfile, please:
MAP
IMAGETYPE PNG
EXTENT -551051 -1288960 -548185 -1286773
SIZE 800 600
SHAPEPATH "data"
IMAGECOLOR 255 255 255
LAYER
NAME "parcely"
DUMP TRUE
STATUS DEFAULT
TYPE POLYGON
CONNECTIONTYPE oraclespatial
CONNECTION uid/pwd at srvcname
DATA "BOUNDARY FROM GR_PARCELY"
PROJECTION
"proj=krovak"
"lat_0=49.5"
"lon_0=24.83333333333333"
"alpha=30.28813972222222"
"k=0.9999"
"x_0=0"
"y_0=0"
"ellps=bessel"
"pm=ferro"
"units=m"
#"init=epsg:4818"
END
CLASS
NAME "parcely"
COLOR 232 232 232
OUTLINECOLOR 32 32 32
END
END
END
Regards,
Jirka
----- Original Message -----
From: "Fortin,Nicolas [SteFoy]" <nicolas.fortin at ec.gc.ca>
To: "Jiri Potocny" <potocny at espace.cz>; <mapserver-users at lists.gis.umn.edu>
Sent: Wednesday, March 17, 2004 5:44 PM
Subject: RE : [Mapserver-users] Unable to display data stored in Oracle Spatial
> Hi Jiri,
> You should use a PROJECTION element in your mapfile for this layer or
> you
should add USING SRID XXXXX at the end of your DATA request.
> Example:
> LAYER
> NAME "3"
> TYPE POLYGON
> CONNECTION "uid/pwd at dbname"
> DATA "GEOLOC FROM USR_WATERSHED.VWTRSD_LCC USING SRID 3000000"
> STATUS OFF
> DUMP TRUE
> PROJECTION
> "proj=lcc"
> "ellps=GRS80"
> "lat_0=63"
> "lon_0=-91.8666"
> "lat_1=49"
> "lat_2=77"
> "x_0=6200000"
> "y_0=2958000"
> "datum=NAD83"
> "units=m"
> END
> CLASS
> NAME "Watershed"
> SYMBOL 'CIRCLE'
> SIZE 2
> COLOR 255 255 255
> OUTLINECOLOR 0 204 0
> END
> END # Watershed
> Nicolas
> Envoyé : Wednesday, March 17, 2004 10:54 AM
> À : mapserver-users at lists.gis.umn.edu
> Objet : [Mapserver-users] Unable to display data stored in Oracle
> Spatial
> Dear MapServer experts,
> could you please help me with following problem?
> I'm trying to display data strored in Oracle Spatial, but I allways
> get a
blank map. The map file is as follows:
> MAP
> IMAGETYPE PNG
> SIZE 800 600
> LAYER
> NAME parcels
> DUMP TRUE
> STATUS DEFAULT
> TYPE POLYGON
> CONNECTION username/password at netservisname
> DATA "BOUNDARY FROM PARCELS"
> CLASS
> COLOR 232 232 232
> END
> END
> END
> If I export the data from oracle into the shapefile and use following
> map
file, everything is O.K.
> MAP
> IMAGETYPE PNG
> SIZE 800 600
> SHAPEPATH "data"
> LAYER
> NAME parcely
> DUMP TRUE
> STATUS DEFAULT
> TYPE POLYGON
> DATA PARCELS
> CLASS
> COLOR 232 232 232
> END
> END
> END
> The only difference is in the data source, the data (attributes as
> well as
> geometries) are the same. I'm running MapServer 4.0.1 with Oracle Spatial
support (downloaded from
> http://hypnos.cbs.umn.edu/projects/downloads/ms401_png_oracle.zip) and
Oracle Database Server version 9.2.0.1.0 on Windows 2000 Professional SP 3.
> Could anybody get throught this problem.
> Much appreciated,
> Jirka
> Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
