[Mapserver-users] Unable to display data stored in Oracle Spatial
Jiri Potocny
potocny at espace.cz
Thu Mar 18 08:27:32 EST 2004
Fernando,
thank you for your hints.
I used Oracle SQL loader utility to import the data:
SQLLDR uid/pwd at srvcname control=parcely log=parcely.log
The data were stored in comma separated value text file in the format like
this:
4|777777||"1"|1|3007|
|pt||||1|1003|1|;-554984,87|-1285550,04|0|-554998,75|-1285529,3200000001|0|-
555001,98999999999|-1285530,8100000001|0|-554984,87|-1285550,04|0|:1|02/13/2
004 00:00:00||
Anyway, I tried to execute SDO_MIGRATE.TO_CURRENT(' TABLE ','
GEOMETRY_COLUMN '), but the problem remains.
Regards,
Jirka
P.S. Your English is perfect enough for this purposes, no need to
appologize.
----- Original Message -----
To: Jiri Potocny ; mapserver-users at lists.gis.umn.edu
Sent: Wednesday, March 17, 2004 6:12 PM
Subject: Re: [Mapserver-users] Unable to display data stored in Oracle
Spatial
Hi Jiri,
I don't know if I can help you. But I will try.
I need to do some questions to help you:
How you imported the data to Oracle?
Using shp2sdo? If yes, after you imported the data, did you execute
this function:
SDO_MIGRATE.TO_CURRENT(' TABLE ',' GEOMETRY_COLUMN ');
If you create a table with geometry columns, and populate it, and
try show it in the mapserv? It appeared in the image?
I don't know if I help you, sorry my poor english.
If you need some help, you can report me.
Fernando Simon - simon at cttmar.univali.br
DataBase Manager, Mapserver, OracleSpatial and PostGis Developer
G10 - Laboratório de Computaçao Aplicada
Fone: 047 - 341 7960
http://g10.cttmar.univali.br
Jiri Potocny wrote:
Dear MapServer experts,
could you please help me with following problem?
I'm trying to display data strored in Oracle Spatial, but I allways get a
blank map.
The map file is as follows:
MAP
IMAGETYPE PNG
EXTENT -551051 -1288960 -548185 -1286773
SIZE 800 600
IMAGECOLOR 255 255 255
LAYER
NAME parcels
DUMP TRUE
STATUS DEFAULT
TYPE POLYGON
CONNECTIONTYPE oraclespatial
CONNECTION username/password at netservisname
DATA "BOUNDARY FROM PARCELS"
CLASS
COLOR 232 232 232
OUTLINECOLOR 32 32 32
END
END
END
If I export the data from oracle into the shapefile and use following map
file, everything is O.K.
MAP
IMAGETYPE PNG
SIZE 800 600
SHAPEPATH "data"
LAYER
NAME parcely
DUMP TRUE
STATUS DEFAULT
TYPE POLYGON
DATA PARCELS
CLASS
COLOR 232 232 232
END
END
END
The only difference is in the data source, the data (attributes as well as
geometries) are the same. I'm running MapServer 4.0.1 with Oracle Spatial
support (downloaded from
http://hypnos.cbs.umn.edu/projects/downloads/ms401_png_oracle.zip) and
Oracle Database Server version 9.2.0.1.0 on Windows 2000 Professional SP 3.
Could anybody get throught this problem.
Much appreciated,
Jirka
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
