[Mapserver-users] Just call me a newbie . . . multiple Raster
LAYERs question {Scanned} {Scanned}
blammo
bob.basques at ci.stpaul.mn.us
Thu Mar 18 09:06:09 EST 2004
This is a multi-part message in MIME format.
--------------070105040903060100080606
Content-Type: text/plain; charset=us-ascii; format=flowed
Content-Transfer-Encoding: 7bit
Siki Zoltan wrote:
>Hi,
>On Wed, 17 Mar 2004, Bob Basques wrote:
>>All,
>>Let's say I have Six different levels of resolution of Aerial Photo's
>>all of them having the same coverage extents.
>It won't work.
>You should create six tile index and six layer and set MINSCALE and
>MAXSCALE for them to turn the best one for a scale. You can add them to
>the same group, so you can easily turn them on and off through the group
>name.
I got it to work as you (and others) described with seperate layers and
using the GROUP option.
>An other solution may be the sid format (may be the ecw to).
>As far as I know ecw is supported in the nightly built version.
>As far as I know MrSid is not supported :(
>These format can contain multi resolution image sources, that case you can
>use the six different resolution tile as one image, that case no need for
>tileindex.
In my experience the MRSID option is too slow to render, I believe the
performance is (much) better using the seperate resolutions as LAYERS.
bobb
Content-Type: text/html; charset=us-ascii
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta content="text/html;charset=ISO-8859-1" http-equiv="Content-Type">
<title></title>
</head>
<body>
Siki Zoltan wrote:
<blockquote
cite="midPine.LNX.4.44.0403180848480.20859-100000 at bme-geod.agt.bme.hu"
type="cite">
<pre wrap="">Hi,
</pre>
<blockquote type="cite">
<pre wrap="">All,
</pre>
</blockquote>
<pre wrap=""><!---->
It won't work.
name.
</pre>
</blockquote>
using the GROUP option.<br>
<blockquote
type="cite">
<pre wrap="">An other solution may be the sid format (may be the ecw to).
tileindex.
</pre>
</blockquote>
performance is (much) better using the seperate resolutions as LAYERS.<br>
<br>
bobb<br>
<br>
</body>
</html>
--------------070105040903060100080606--
