[Mapserver-users] Question about wld/gfw file
Lowell Filak
lfilak at medinaco.org
Thu Mar 18 09:34:35 EST 2004
Hopefully this will help.
tp_genmap.wld
1
0
-0
-1
0
300
your.map
MAP
STATUS ON
IMAGETYPE GIF
EXTENT 0 0 400 300
SIZE 400 300
SHAPEPATH "C:\Program Files\Apache Group\Apache2\htdocs\tutorial\data"
IMAGECOLOR 255 255 255
UNITS METERS
# Start of LAYER DEFINITIONS
LAYER # States polygon layer begins here
NAME tp_genmap
DATA "tp_genmap.gif"
STATUS DEFAULT
TYPE RASTER
END # States polygon layer ends here
# End of LAYER DEFINITIONS
END # end of map file/object
Lowell
The following message was sent by "Lowell Filak" <lfilak at medinaco.org>
on Thu, 18 Mar 2004 08:41:23 -0500.
> If my understanding is correct - what you are trying to do is generate a
> map elsewhere and save it as an image (gif file) and then serve that
> "raster" layer up using mapserver.?
> If that understanding is correct then the answer to "Do I need to create
> a new wld/gfw file for each of my own maps?" is yes.
> If all your doing is serving up a single raster layer (the map image)
> then you can use just about any coordinates you would like in the wld
> file because the image will not need to relate to any other data.
> Keep in mind that you can't serve a scalebar with this approach as it
> will be incorrect.
> Example (this is a quick example so I may need corrected here): If the
> image is 1000x1000 then the wld could be:
> 1
> 0
> -0
> -1
> 0
> 1000
> and the mapfile extent would be 0 0 1000 1000
> HTH
> Lowell
> The following message was sent by =?iso-8859-1?q?TOH=20CZ?=
> <cz_toh at yahoo.com> on Thu, 18 Mar 2004 06:22:32 +0000 (GMT).
> > Hi, I have a few questions about the wld/gfw files
> > used in mapserver
> > 1) Do I need to create a new wld/gfw file for each of
> > my own maps?
> > 2) How do you determine what to put into the wld/gfw
> > file?
> > I tried searching the archives, I could not find one
> > that contained information about using GIF files
> > Right now, my file shows a blank GIF image
> > MAP
> > IMAGETYPE GIF
> > EXTENT 201621.496941 -294488.285333
> > 1425518.020722 498254.511514
> > SIZE 400 300
> > PROJECTION
> > "proj=laea"
> > "ellps=clrk66"
> > "lat_0=45"
> > "lon_0=-100"
> > # Alternatively, you can specify an EPSG code.
> > # "init=epsg:2163"
> > END
> > NAME tp_genmap
> > STATUS DEFAULT
> > TYPE RASTER
> > PROJECTION
> > "init=epsg:4326"
> > END
> > CLASS
> > COLOR 232 232 232
> > OUTLINECOLOR 32 32 32
> > END
> > Thanks
> > ___________________________________________________________
> > Yahoo! Messenger - Communicate instantly..."Ping"
> > your friends today! Download Messenger Now
> > http://uk.messenger.yahoo.com/download/index.html
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
