[Mapserver-users] Extent
bartvde at xs4all.nl
Fri Mar 19 02:37:42 EST 2004
try
EXTENT -95.809105 41.500326 -82.209468 48.311024
It should be the same as the OGRinfo Extent if you want to see your
complete dataset. The syntax in OGR Extent is:
(Xmin, YMin) - (XMax, YMax)
Best regards,
Bart
> Hello !
> I use AcrWiew 3.0 software to create shapefiles (.dbf, .shp, .shx
> extention).
> Example : vung.dbf
> I Open file `vung.dbf' using driver `ESRI Shapefile'
> Layer name: vung
> Geometry: Polygon
> Feature Count: 7
> Extent: (-95.809105, 41.500326) - (-82.209468, 48.311024)
> Layer SRS WKT:
> (unknown)
> TENVUNG: String (16.0)
> LOP: String (16.0)
> OGRFeature(vung):0
> ID (Integer) = 0
> TENVUNG (String) = mÝnota
> LOP (String) = nuoc
> POLYGON ((-95.80910507 48.31102390,-93.32853131 47.70176017,-94.41650226
> 47.37536889,-95.80910507 48.31102390))
> OGRFeature(vung):1
> ID (Integer) = 0
> TENVUNG (String) = bfdb
> example.map:
> MAP
> IMAGETYPE PNG
> EXTENT -95.809105 41.500326 82.209468 -48.311024
> SIZE 400 300
> SHAPEPATH "data"
> PROJECTION
> "proj=laea"
> "ellps=clrk66"
> "lat_0=45"
> "lon_0=-100"
> # Alternatively, you can specify an EPSG code.
> # "init=epsg:2163"
> END
> # Start of LAYER DEFINITIONS
> LAYER # States polygon layer begins here
> NAME vung
> DATA vung
> STATUS DEFAULT
> TYPE POLYGON
> PROJECTION
> "init=epsg:4326"
> END
> CLASSITEM "LOP"
> CLASS
> EXPRESSION 'dat'
> COLOR 32 132 255
> END
> CLASS
> COLOR 32 132 255
> END
> CLASS
> EXPRESSION 'nuoc'
> COLOR 198 198 255
> END
> END
> END # End mapfile
> But Image don't create without an error ?
> I don't understand what happened ?
> Can you tell me about " Extent" in Shapefile (e.g vung.dbf) relative with
> "Extent" in mapfile (e.g example.map)
> Thank you very much.
> Do you Yahoo!?
> Yahoo! Mail - More reliable, more storage, less spam
