[Mapserver-users] Unable to display map
Eduardo Patto Kanegae
eduardo at consultoria.eti.br
Fri Mar 19 06:24:21 EST 2004
OK. it show that your MAP_STATUS is set to ON, so to display it at the
browser you should
at the reserved word [img] inside your template file like this:
The map:<input type="image" name="img" src="[img]" >
Pramila R Gawas escreveu:
> Thanks for immediate replying
> actually if i just try to display the static map without webaddress,
> it works fine.
> but when i try to display it using web address, it creates a png image
> in ~user/tmp file.. doesn't display in browser.
> Eduardo Patto Kanegae wrote:
>> Did you check if your shapefile has this extent value? EXTENT -180
>> -90 180 90
>> A good way to check is to use "shpdump" tool from ShapeLib (
>> http://shapelib.maptools.org )
>> $ shpdump myshapefile.shp > mydumpfile.txt
>> open the TXT file and look for line 3 and 4.
>> that's all u need.
>> best.
>> http://www.consultoria.eti.br
>> ## Projeto MapServer Brasil - http://mapserver.cttmar.univali.br ##
>> ***Fim da Mensagem / End of Message ***
>>> Dear MapServer experts,
>>> could you please help me with following problem?
>>> I'm trying to display data strored in shape file, but I allways get a
>>> blank map (image icon).
>>> The map file is as follows :
>>> NAME WORLD
>>> SIZE 500 650
>>> EXTENT -180 -90 180 90
>>> #UNITS METERS
>>> SHAPEPATH "/localhostname/user/abc/public_html/worldmap/data"
>>> STATUS ON
>>> #IMAGETYPE png
>>> LAYER
>>> NAME world
>>> TYPE POLYGON
>>> DATA world
>>> CLASS
>>> COLOR 181 181 181
>>> OUTLINECOLOR 50 10 100
>>> END
>>> STATUS DEFAULT
>>> END
>>> PROJECTION
>>> "proj=latlong"
>>> END
>>> WEB
>>> TEMPLATE demo.html
>>> IMAGEPATH "set in init.html"
>>> IMAGEURL "set in init.html"
>>> METADATA
>>> WMS_ONLINERESOURCE "http://localhost/~abc/init.html"
>>> END
>>> END
>>> END
>>> Could anybody get throught this problem.
>>> thanks
>>> pramila
>>> Mapserver-users mailing list
>>> Mapserver-users at lists.gis.umn.edu
>>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
