[Mapserver-users] msyyparse() - parse error
Möri Cédric
Cedric.Moeri at bd.so.ch
Mon Mar 22 05:27:42 EST 2004
This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
------_=_NextPart_000_01C40FF8.4F464D90
Content-Type: text/plain;
charset="ISO-8859-1"
Content-Transfer-Encoding: quoted-printable
Hello list!
we recently upgraded our systems from
MapServer3.6.6/postgreSQL7.2.4/postgis0.8.0 to
MapServer4.0.1/postgreSQL7.4.2/postgis0.8.1. The system is running =
under
Linux RH7.2.
Now i'm reciving sometimes this strange error "msyyparse(): Expression
parser error. parse error".
(In the old version, everyting worked perfect!)
I'm not able to reproduce this error regularly. Sometimes it triggers =
when
i'm switching some layers on/off, sometimes it triggers when i'm just =
paning
(same layer-set/same scale). Sometimes it triggers only one time, =
othertimes
up to 60 times with still the same mapfile.=20
I read from the archives that there might be some issue about the =
querrying
in postgis but there is not much more.
So I guess I'm stuck. Has anybody a hint for me in which direction to =
go on
with my quest? May anybody explain what the msyyparse does, and when it =
is
called?
Any hint would be appreciated!
If needed I would be glad to provide further information.
best regards
mit freundlichen Gr=FCssen
C=E9dric M=F6ri
Kanton Solothurn
Amt f=FCr Geoinformation
Abt. SO!GIS Koordinationsstelle=20
R=F6tihof
4509 Solothurn
T: ++41 (0)32 627 2475
Fax: ++41 (0)32 627 2214=20
http://www.sogis.so.ch
Content-Type: application/octet-stream;
name="=?ISO-8859-1?Q?M=F6ri_C=E9dric=2Evcf?="
Content-Disposition: attachment;
filename="=?ISO-8859-1?Q?M=F6ri_C=E9dric=2Evcf?="
BEGIN:VCARD
VERSION:2.1
N:M=F6ri;C=E9dric
FN:M=F6ri C=E9dric
ORG:Bau- Departement;Amt f=FCr Raumplanung
ADR;WORK:;;;Solothurn
LABEL;WORK:Solothurn
EMAIL;PREF;INTERNET:Cedric.Moeri at bd.so.ch
REV:20020605T094013Z
END:VCARD
------_=_NextPart_000_01C40FF8.4F464D90--
