[Mapserver-users] mapserver_ChangeLog.txt
Stepan Kafka
stepan.kafka at centrum.cz
Tue Mar 23 10:33:58 EST 2004
Please, where is the actual mapserver_ChangeLog.txt file now?
At DM Solution web site is only old version from june 2003
(http://www.maptools.org/dl/mapserver_ChangeLog.txt)
Thank you
Stepan Kafka
> -----Pùvodní zpráva-----
> Od: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu]za uivatele Steve Lime
> Odesláno: 22. bøezna 2004 17:38
> Komu: Cedric.Moeri at bd.so.ch; mapserver-users at lists.gis.umn.edu
> Pøedmìt: Re: [Mapserver-users] msyyparse() - parse error
> Hi there: Msyyparse() is the function that evaluates MapServer
> expressions. There
> are 3 possibilities:
> 1) There is an error in the expression you're using.
> 2) There is something funky in your data, that breaks an expression.
> 3) There is an error in the code itself.
> Although 1) and 3) are possible they seem unlikely. My guess is
> that there is an
> issue with certain data values and the expressions. One example would be
> data values containing embeded quotes. Let's say you had a place name
> called O'Reilly and where using an expression like:
> ('[placename]' = 'foo') which would become in the case of O'Reilly,
> ('O'Reilly' = 'foo') and this would cause a parse error.
> Could also happen with numeric fields that didn't contain numbers
> or are empty.
> We'd really need to see your mapfile to make the call.
> Steve
> >>> Möri Cédric <Cedric.Moeri at bd.so.ch> 3/22/2004 4:27:42 AM >>>
> Hello list!
> we recently upgraded our systems from
> MapServer3.6.6/postgreSQL7.2.4/postgis0.8.0 to
> MapServer4.0.1/postgreSQL7.4.2/postgis0.8.1. The system is running under
> Linux RH7.2.
> Now i'm reciving sometimes this strange error "msyyparse(): Expression
> parser error. parse error".
> (In the old version, everyting worked perfect!)
> I'm not able to reproduce this error regularly. Sometimes it triggers when
> i'm switching some layers on/off, sometimes it triggers when i'm
> just paning
> (same layer-set/same scale). Sometimes it triggers only one time,
> othertimes
> up to 60 times with still the same mapfile.
> I read from the archives that there might be some issue about the
> querrying
> in postgis but there is not much more.
> So I guess I'm stuck. Has anybody a hint for me in which
> direction to go on
> with my quest? May anybody explain what the msyyparse does, and when it is
> called?
> Any hint would be appreciated!
> If needed I would be glad to provide further information.
> best regards
> mit freundlichen Grüssen
> Cédric Möri
> Kanton Solothurn
> Amt für Geoinformation
> Abt. SO!GIS Koordinationsstelle
> Rötihof
> 4509 Solothurn
> T: ++41 (0)32 627 2475
> Fax: ++41 (0)32 627 2214
> http://www.sogis.so.ch
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
