[Fwd: Re: [Mapserver-users] WFS Anyone?]
Keith Campbell
scoota at supanet.com
Tue Mar 23 18:17:41 EST 2004
Frank,
Setting the PROJ_LIB environment variable via the Apache configuration
file has done the trick.
Thanks again.
Keith
-------- Original Message --------
Subject: Re: [Mapserver-users] WFS Anyone?
Date: Tue, 23 Mar 2004 20:48:59 +0000
Reply-To: scoota at supanet.com
To: Frank Warmerdam <warmerdam at pobox.com>
References: <405E201E.7080900 at supanet.com> <405E3904.9080704 at pobox.com>
<405F6156.3090108 at supanet.com> <405F661C.5040302 at pobox.com>
<405F7326.8090500 at supanet.com> <405FA694.3050202 at pobox.com>
Frank,
That's excellent information, thanks for taking the time. I must admit
I'm relatively new to UNIX and it's a dark and mysterious world to me.
I'll request the server administrator to alter the Apache httpd.conf
file to include your suggested 'SetEnv' statement.
Cheers,
Keith
Frank Warmerdam wrote:
> Keith Campbell wrote:
>> Frank,
>> The files you speak of appear to be in /export/home/local/util/proj/nad
>> Assuming that this location is not being picked up, I set PROJ_LIB to
>> point to this directory. However, that didn't resolve the problem.
>> Possibly this is due to the fact i don't have admin rights, and
>> although the variable was reported to have changed, when I logged out
>> and back in again, the variable was not set. I think I will need to
>> get the server administrator to set this variable and try again?
> Keith,
> I gather you are working on unix. To set an environment variable on unix
> in such a way that it will affect a cgi-bin you will normally need to add
> a "SetEnv" directive in your apache configuration file. Something like:
> SetEnv PROJ_LIB /export/home/local/util/proj/nad
> Alternatively, you can setup a "cover script" for mapserver that sets
> appropriate environment variables. I have used a shell script like the
> following in the past.
> #! /bin/sh
> MS_MAPFILE=/u/www/gmap/htdocs/gmap75.map
> export MS_MAPFILE
> /u/pkg/mapserver/mapserv
> exit 0
> In general setting an environment variable at the command line on Unix
> just sets in in that shell instance, and subshells. It has no external
> effect. To set it everytime you login, add it to your shell startup
> file.
> To add it for all users there is usually a shell startup script in
> /etc that
> can be altered though I seldom do it that way. In any event, it might
> not
> have the desired effect on web servers that aren't started directly
> from a
> shell. There is no equivelent to the "global" environment of Windows NT.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
