[Mapserver-users] How to Embedded text or image in map
Emil Zegers
EZS at DeStraat.NL
Wed Mar 24 07:43:17 EST 2004
Hello Xavier,
You can embed positioned elements like text or elements the following
way:
LAYER
NAME "credits"
STATUS DEFAULT
TRANSFORM FALSE
TYPE ANNOTATION
FEATURE
POINTS
10, 10
END
TEXT 'www.strategis.fr'
END
CLASS
LABEL
TYPE TRUETYPE
FONT "arial"
SIZE 11
ANTIALIAS TRUE
COLOR 0 0 0
END
END
END
This layer should be added as the last layer in the map file to show on
top.
Same for images (this could be the scaelbar, however you will need some
serverside scripting to rename/copy the current scalebar to the defined
path/filename provided in the layer, I don't know how to get this
dynamic)
LAYER
NAME "scalebar"
TYPE RASTER
STATUS DEFAULT
TRANSFORM FALSE
DATA "/path/to/file/scalbar.png"
END
Best regards,
Emil Zegers
>>> "Xavier Mauclaire" <xavier.mauclaire at strategis.fr> 03/24/04 11:03am
Hi
i'd like to embed en simple text in the map image generated by
mapserver.
As i can embed the scalebar i'd like to do the same thing with e text
or a
image.
regards
Xavier MAUCLAIRE
Conseils et développements en SIG STRATEGIS S.A.
Parc 2000
19, rue Joe Dassin
34184 Montpellier Cedex 4
Tél. +33 (0) 4.67.40.75.40
Fax +33 (0) 4.67.40.75.41
www.strategis.fr
______________________________________________________
This message has been checked for all known viruses
