[Mapserver-users] Re: mouse coordinates
Richard Greenwood
rich at greenwoodmap.com
Thu Mar 25 14:17:27 EST 2004
steve mccrone wrote:
> Hi Richard,
> Sorry to bother you again. But I am trying to implement a bearing
> calculation with the measure tool in jBox.
> In order to do this I need the "anchor" mouse coordinate and the current
> mouse coordinate. The current is no problem,
> can get it from the mosuemove handler, but how do I get the initial click
> coordinate in order to calculate the bearing of the line?
> I only see the setbox_handler function, which does not appear to be called
> when the line is on.
You might look at the vertex count (n) which is submitted to
measure_handler().
Each time the the mouse has moved more than tolerance(pixels) the
measure_handler() function gets called, and mosuemove_handler() gets
called if verbose=true. And each time the user clicks in line mode, n
gets incremented. So code in measure_handler() something like:
if (n > old_n) {
anchor.x = mouse.x;
anchor.y = mouse.y;
old_n = n;
where mouse.x and mouse.y are being updated by mousemove_handler().
Richard Greenwood
www.greenwoodmap.com
