[Mapserver-users] PB with mapinfo table query
Frank Rittinger
gis at schnegg.net
Fri Mar 26 04:08:17 EST 2004
Salut Xavier,
I think the templates are case sensitive, i.e. [id] must be [ID].
One guess for the others would be that the names in the MapInfo data
file (actually a dbase file) are different than the ones in the TAB file
(OGR or mitab maintainers will know exactly). I had a similar problem
after I renamed column names in MapInfo or after copying mapinfo tables.
Try to create a new table (with short column names) and fill it with
the data of your original table.
Regards, Frank
Xavier Mauclaire wrote:
> Definition Table
> Type NATIVE Charset "WindowsLatin1"
> Fields 10
> ID Integer Index 1 ;
> TYPE Char (3) ;
> ORIENTATIO Decimal (16, 3) ;
> NODE_ Decimal (11, 0) ;
> SYMBOL Decimal (5, 0) ;
> NETSTAT Decimal (3, 0) ;
> IDENT Decimal (6, 0) ;
> OBSERV Char (128) ;
> BITNUM Decimal (5, 0) ;
> BITCAN Char (254) ;
> my template file is
> <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
> <html>
> <head>
> <title>Interrogation PPR</title>
> <link rel="stylesheet" type="text/css" href="[web_cheminsite]style.css">
> </head>
> <body onBlur="window.focus()">
> <table>
> <tr><td><b> ORGANE : </b> </td></tr>
> <tr><td><b> ID : </b> [id] </td></tr>
> <tr><td><b> TYPE : </b> [TYPE] </td></tr>
> <tr><td><b> NODE : </b> [NODE_] </td></tr>
> <tr><td><b> Orientation : </b> [ORIENTATIO] </td></tr>
> <tr><td><b> Observations : </b> [OBSERV] </td></tr>
> <tr><td><b> bitnum : </b> [BITNUM] </td></tr>
> <tr><td><b> bitcan : </b> [BITCAN] </td></tr>
> </table>
> </body>
> </html>
> In this sample :
> [ID] value is replace with a very big number but not the good value
> [NODE_], [ORIENTATIO]and [BITCAN] are not replaced.
> the result is
> *ORGANE : *
> *ID : *10802878981808
> *TYPE : *1
> *NODE : *[NODE_]
> *Orientation : *[ORIENTATIO]
> *Observations : *SIGVD
> *bitnum : *370
> *bitcan : *[BITCAN]
