[Mapserver-users] tile indexing problem
Antonio Cosenza
antonio.cosenza at polito.it
Fri Mar 26 09:16:57 EST 2004
>Dear
>I think first you can try to check your path and make data there. And Test it
>and tell us what is your result?
a question before to prceed with the test... in the shapefile field
"Nome" do i have all the filename records compiled? i mean, can i have
some empty records?
thanks
>Sarawut
>Quoting Antonio Cosenza <antonio.cosenza at polito.it>:
>>but wherecan i found information about raster type and tile indexing? i
>>mean, i have to use tiff files only??
>>thanks
>>sarawut at ait.ac.th wrote:
>>>Dear
>>>Could you check dbf file that in field of "Name" should has a relative path
>>>from "data path" to your file also. Such if your image are in
>>"\data\image\F4-
>>>N2.jpg". your shp file should has "image\F4-N2.jpg"
>>>But please check potential of file format I think only TIFF can support Tile
>>>http://mapserver.gis.umn.edu/doc40/raster-howto.html#
>>>Best Regards
>>>Sarawut
>>>>hi guys,
>>>>i got a little problem with mapserver tile indexing.
>>>>This is my situation:
>>>>- i got a polygon shape file (raster.shp) of rectangular polygons with 9
>>>>attributes in the dbf file (raster.dbf).
>>>>- one of the attribute's names is 'Nome', which contains the raster
>>>>file name, like F4-N2.jpg.
>>>>- i have a directory that contains all the jpeg tiles (F4-N2.jpg, and so
>>>>on )
>>>>can i use this layer to see my jpeg raster files draw up ?
>>>>LAYER
>>>> NAME "raster"
>>>> STATUS ON
>>>> TILEINDEX "ratser.shp"
>>>> TILEITEM "Nome"
>>>> TYPE RASTER
>>>>END
>>>>thanksss
>>>>toni
>>>>_______________________________________________
>>>>Mapserver-users mailing list
>>>>Mapserver-users at lists.gis.umn.edu
>>>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
>>>This mail sent through AIT WebMail : http://www.ait.ac.th/
