[Mapserver-users] mapserv compiling error
John Beisley - RSG
josb at pml.ac.uk
Mon Mar 29 08:50:33 EST 2004
You want the GD library development version 2 package installed. How you
do this depends on the distribution that you are using.
ESSC Admin wrote:
> When running ./configure on my remote webserver, these errors appear:
> loading cache ./config.cache
> checking for gcc... gcc
> checking whether the C compiler (gcc ) works... yes
> checking whether the C compiler (gcc ) is a cross-compiler... no
> checking whether we are using GNU C... yes
> checking whether gcc accepts -g... yes
> checking for c++... c++
> checking whether the C++ compiler (c++ ) works... yes
> checking whether the C++ compiler (c++ ) is a cross-compiler... no
> checking whether we are using GNU C++... yes
> checking whether c++ accepts -g... yes
> checking for ranlib... ranlib
> checking for flex... flex
> checking for yywrap in -lfl... yes
> checking for bison... bison -y
> checking if compiler supports -R... no
> checking if compiler supports -Wl,-rpath,... yes
> checking for exp in -lm... yes
> checking for __gxx_personality_v0 in -lstdc++... no
> checking how to run the C preprocessor... /lib/cpp
> checking for ANSI C header files... no
> checking for strcasecmp... no
> checking for strncasecmp... no
> checking for strdup... no
> checking whether we should include JPEG support...
> checking for jpeg_read_header in -ljpeg... yes
> using libjpeg from system libs.
> checking where FreeType 2.x is installed...
> checking for FT_Init_FreeType in -lfreetype... yes
> using libfreetype -lfreetype from system libs.
> checking where Zlib is installed...
> checking for zlibVersion in -lz... yes
> using libz from system libs.
> checking where PNG is installed...
> checking for png_init_io in -lpng... yes
> using libpng from system libs.
> checking where libXpm is installed...
> checking for XpmFreeXpmImage in -lXpm... no
> XPM (libXpm) library cannot be found, possibly needed for GD
> checking where libiconv is installed...
> checking for libiconv_open in -liconv... no
> libiconv library cannot be found, possibly needed for GD
> checking for GD 2.0.12 or higher...
> checking for gdImageSetAntiAliased in -lgd... yes
> checking for gdImageSetAntiAliased in -lgd... (cached) yes
> configure: error: Could not find gd.h or libgd.a/libgd.so in
> /usr/local. Make su
> re GD 2.0.12 or higher is compiled before calling configure.
> What should I do next? I a newbie at linux so please bear with me. Thanks.
> Regards
Website: www.pml.ac.uk
Registered Charity No. 1091222
Company No. 4178503
This e-mail, its content and any file attachments are confidential.
If you have received this e-mail in error please do not copy,
disclose it to any third party or use the contents or attachments
in any way. Please notify the sender by replying to this e-mail or
e-mail forinfo at pml.ac.uk and then delete the email without making
any copies or using it in any other way.
The content of this message may contain personal views which are
not the views of Plymouth Marine Laboratory unless specifically
stated.
Email transmission cannot be guaranteed to be secure or error free
