[Mapserver-users] Problems compiling mapserv with OGR support.
Tyler Mitchell
TMitchell at lignum.com
Tue Mar 30 11:43:40 EST 2004
Hi Seb,
If you can, I'd suggest also compiling gdal/ogr from source code. I
assume the versions you have are linux binaries that may not have all the
required files for effectively building dependent applications.
You may also try running: ldconfig
that should get your libraries registered. You may first want to edit
/etc/ld.so.conf (I think I got the write path there) and make sure that
the folder that the libraries you want is listed there - then run ldconfig
again.
There is also a gdal/ogr list that may help you.
Tyler
mapserver-users-admin at lists.gis.umn.edu wrote on 03/30/2004 06:48:32 AM:
> Hello everybody :)
> First excuse me for my english, I'm french :)
> I'm trying to enable OGR support for mapserv, so I'm trying to compile
> it as follow :
> [root at nostalgia mapserver-4.0.1]# ./configure
> --with-ogr=../gdal-1.2.0b/apps/gdal-config \
> --with-gdal=../gdal-1.2.0b/apps/gdal-config
> [root at nostalgia mapserver-4.0.1]# make
> But i've lots of errors durring make (configure scripts works fine) :
> > gcc -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF
> > -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT
> > -DUSE_GDAL -I/usr/include
> > -I/root/applications/mapserver/gdal-1.2.0b/port
> > -I/root/applications/mapserver/gdal-1.2.0b/gcore
> > -I/root/applications/mapserver/gdal-1.2.0b/alg
> > -I/root/applications/mapserver/gdal-1.2.0b/ogr
> > -I/root/applications/mapserver/gdal-1.2.0b/ogr/ogrsf_frmts
> > shp2img.o -L. -lmap -lgd -L/usr/lib -lgd -ljpeg -lfreetype -lpng
> > -lz -ltiff -ljpeg -lfreetype -lpng -lz -ljpeg -lm
> > -lstdc++ -o shp2img
> > ./libmap.a(mapgdal.o)(.text+0x11): In function `msGDALInitialize':
> > : undefined reference to `GDALAllRegister'
> > ./libmap.a(mapgdal.o)(.text+0x19): In function `msGDALInitialize':
> > : undefined reference to `CPLQuietErrorHandler'
> > ./libmap.a(mapgdal.o)(.text+0x1e): In function `msGDALInitialize':
> > : undefined reference to `CPLPushErrorHandler'
> <snip> lot's of others
> > ./libmap.a(mapdrawgdal.o)(.text+0x26b9): In function `Dither24to8':
> > : undefined reference to `GDALDestroyColorTable'
> > ./libmap.a(mapdrawgdal.o)(.text+0x26c6): In function `Dither24to8':
> > : undefined reference to `GDALClose'
> > collect2: ld returned 1 exit status
> > make: *** [shp2img] Erreur 1
> I've tried to update to gdal 1.2.0b but no results :(
> Here is some additionals informatitions that could help I hope.
> [root at nostalgia mapserver-4.0.1]# locate libgdal.so.1.2.0
> /root/applications/mapserver/gdal-1.2.0/.libs/libgdal.so.1.2.0
> /root/applications/mapserver/gdal-1.2.0b/.libs/libgdal.so.1.2.0
> /usr/local/lib/libgdal.so.1.2.0
> I've heard that there where some problems with gcc 3 and mapserv, so
> here is my output :
> [root at nostalgia mapserver-4.0.1]# gcc -v
> Reading specs from /usr/lib/gcc-lib/i586-mandrake-linux-gnu/3.3.1/specs
> Configured with: ../configure --prefix=/usr --libdir=/usr/lib
> --with-slibdir=/lib --mandir=/usr/share/man --infodir=/usr/share/info
> --enable-shared --enable-threads=posix --disable-checking
> --enable-long-long --enable-__cxa_atexit
> --enable-languages=c,c++,ada,f77,objc,java,pascal
> --host=i586-mandrake-linux-gnu --with-system-zlib
> Thread model: posix
> gcc version 3.3.1 (Mandrake Linux 9.2 3.3.1-2mdk)
> I don't know how to proceed to solve this problem, cause I am Linux
> newbie :(
> Searching the mailing list archives I've found that the "ldd" program
> must be use, I don't know how it works, but I've understand that it
> register system librairies, here is the output :
> > [root at nostalgia mapserver-4.0.1]# ldd /usr/local/lib/libgdal.so.1.2.0
> > libungif.so.4 => /usr/lib/libungif.so.4 (0x402fe000)
> > libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0x40306000)
> > libpng.so.3 => /usr/lib/libpng.so.3 (0x40325000)
> > libz.so.1 => /lib/libz.so.1 (0x4034b000)
> > libdl.so.2 => /lib/libdl.so.2 (0x4035a000)
> > libpq.so.3 => /usr/lib/libpq.so.3 (0x4035d000)
> > libstdc++.so.5 => /usr/lib/libstdc++.so.5 (0x40372000)
> > libm.so.6 => /lib/i686/libm.so.6 (0x4042b000)
> > libc.so.6 => /lib/i686/libc.so.6 (0x4044e000)
> > libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x4057e000)
> > libX11.so.6 => /usr/X11R6/lib/libX11.so.6 (0x40588000)
> > /lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x80000000)
> > libssl.so.0.9.7 => /usr/lib/libssl.so.0.9.7 (0x4066b000)
> > libcrypto.so.0.9.7 => /usr/lib/libcrypto.so.0.9.7 (0x4069d000)
> > libcrypt.so.1 => /lib/libcrypt.so.1 (0x4079f000)
> > libresolv.so.2 => /lib/libresolv.so.2 (0x407cc000)
> > libnsl.so.1 => /lib/libnsl.so.1 (0x407dd000)
> > [root at nostalgia mapserver-4.0.1]# ldd libgdal.so.1.2.0
> > ldd: ./libgdal.so.1.2.0: No such file or directory
> Seems to be a problem ?
> I've also read an answer for a problem similar to mine, where *Daniel
> Morissette *said to try the following command :
> > [root at nostalgia mapserver-4.0.1]# nm /usr/local/lib/libgdal.so.1.2.0 |
> > grep OGRPolygon
> > 0015bbf0 T _Z14OGRGetCentroidP10OGRPolygonP8OGRPoint
> > 0015b4e0 T _Z20OGRPolygonLabelPointP10OGRPolygonP8OGRPoint
> > 0015b460 T _Z24OGRIntersectPointPolygonP8OGRPointP10OGRPolygon
> > 001be0a0 T _ZN10OGRPolygon11flattenTo2DEv
> > 001be320 T _ZN10OGRPolygon13importFromWkbEPhi
> > 001be6e0 T _ZN10OGRPolygon13importFromWktEPPc
> > 001be250 T _ZN10OGRPolygon15addRingDirectlyEP13OGRLinearRing
> > 001be100 T _ZN10OGRPolygon15getExteriorRingEv
> > 001be160 T _ZN10OGRPolygon15getInteriorRingEi
> > 001bdfa0 T _ZN10OGRPolygon5emptyEv
> > 001be1c0 T _ZN10OGRPolygon7addRingEP13OGRLinearRing
> > 001bed80 T _ZN10OGRPolygon9transformEP27OGRCoordinateTransformation
> > 001bdd90 T _ZN10OGRPolygonC1Ev
> > 001bdd50 T _ZN10OGRPolygonC2Ev
> > 001bdeb0 T _ZN10OGRPolygonD0Ev
> > 001bde40 T _ZN10OGRPolygonD1Ev
> > 001bddd0 T _ZN10OGRPolygonD2Ev
> > 00150ff0 T
_ZN9TABRegion13AppendSecHdrsEP10OGRPolygonRP19TABMAPCoordSecHdr_tP10TABMAPFileRi
> > 001be5a0 T _ZNK10OGRPolygon11exportToWkbE15OGRwkbByteOrderPh
> > 001be9a0 T _ZNK10OGRPolygon11exportToWktEPPc
> > 001beb50 T _ZNK10OGRPolygon11getEnvelopeEP11OGREnvelope
> > 001be050 T _ZNK10OGRPolygon12getDimensionEv
> > 001beb40 T _ZNK10OGRPolygon14PointOnSurfaceEP8OGRPoint
> > 001be120 T _ZNK10OGRPolygon15getExteriorRingEv
> > 001be0e0 T _ZNK10OGRPolygon15getGeometryNameEv
> > 001be020 T _ZNK10OGRPolygon15getGeometryTypeEv
> > 001be190 T _ZNK10OGRPolygon15getInteriorRingEi
> > 001be140 T _ZNK10OGRPolygon19getNumInteriorRingsEv
> > 001be060 T _ZNK10OGRPolygon22getCoordinateDimensionEv
> > 001bdf20 T _ZNK10OGRPolygon5cloneEv
> > 001bec80 T _ZNK10OGRPolygon5EqualEP11OGRGeometry
> > 001be2a0 T _ZNK10OGRPolygon7WkbSizeEv
> > 001beb30 T _ZNK10OGRPolygon8CentroidEP8OGRPoint
> > 001beb10 T _ZNK10OGRPolygon8get_AreaEv
> > 002cf658 V _ZTI10OGRPolygon
> > 0024d276 V _ZTS10OGRPolygon
> > 002cf560 V _ZTV10OGRPolygon
> So here is my output.
> I don't know what is the problem, and where it is.
> I hope you know this problem and how to solve it :/
> Thanks in advance,
> seb :)
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
