[Mapserver-users] drawing lines with mapscript
    blaise
    bpicinbono at worldonline.fr
    Wed Mar 31 00:29:53 PST 2004
hi jeff,
I hope that this will help. This is a php-function that draw a line
(according to several parameters). It is working fine with MS 3.6.2;
perhaps you have to make some changes for MS 4.0. Try to put your own
parameters and it should work fine.
Blaise
/*    function line_save(tx,ty,layername,id,type,close,kt)   */
/* make a line  out of arrays tx and ty, */
/*  if id=0->newid  else id=id                      */
/*  type : line=3, poly=5     if close,             */
/* add the first point at the end                   */
function line_save($tx,$ty,$sln,$sid,$stype,$sclose,$kt)
$shapepath="/var/www/html/ms/data";
$numpoint=count($tx);
if ( (($numpoint>1) and ($stype==3)) or (($numpoint>2) and ($stype=="5")) )
  $stmp="/$sln";
  $lineshpFileName="$shapepath"."$stmp";
  $lineshpFile = ms_newShapefileObj($lineshpFileName,-2);
  $newShp = ms_newShapeObj(MS_SHP_ARC);
  $aLine = ms_newLineObj();
  for ($ipoint=0; $ipoint<$numpoint;$ipoint++)
   $aLine->addXY($tx[$ipoint], $ty[$ipoint]);
  if ($sclose==1)
   $aLine->addXY($tx[0], $ty[0]);
  $newShp->add($aLine);
  $lineshpFile->addShape($newShp);
  $aLine->free();
  $newShp->free();
  $dbFile = dbase_open($lineshpFileName,2);
  if ($sid==0)
   $idfn=$sln.".id";
   $filename="$shapepath"."/$idfn";
   $fp=fopen($filename,"r") or die ("not able to open $filename in read
mode");
   $id=fgets($fp,1024);
   fclose($fp);
   $id=$id+1;
   $fp=fopen($filename,"w") or die ("not able to open $filename in write
mode");
   fwrite ($fp,$id);
   fclose($fp);
   $c[0]=$id;
  else
   $c[0]=$sid;
   dbase_add_record($dbFile,$c);
   dbase_close($dbFile);
   $lineshpFile->free();
//***************** end line_save ***************************
More information about the MapServer-users
