[Mapserver-users] Problem with SDE connection
Norbert Thieme
norbert.thieme at ilmenau.baw.de
Wed Mar 31 09:49:23 EST 2004
Hi!
I'm setting up a Mapserver (version 4.0.1), that should use ESRI's
ArcSDE as data source. The Mapserver is running under SuSE Linux 8 and
ArcSDE is running on Informix under HP UX. Because I couldn't find a SDE
Client for SuSE Linux and Informix on the SDE Install CD, I compiled the
Mapserver with the RedHat - Oracle version.
Can someone please tell me if this is a possible way? If not, do anybody
know a SDE Client for my configuration or is there another way to get
that running? - If this is definitely the wrong way you can stop reading
here.
Everything is running fine apart from the results of the SDE Connection.
I set up a simple mapfile with only one Layer with a SDE Connection
(please see below). In this mapfile I tried different alternatives for
the connection because I was not sure how the parameters have to look
like in detail. The result from this was in all the cases a blank map
(empty picture) and there is no error message. If the reason for the
blank map comes not from the wrong client, how can I check where
something is wrong. Is there a way to check for example the connection
to the SDE or to get some kind of error message to determine the problem?
My mapfile:
MAP
IMAGETYPE PNG
STATUS ON
SIZE 400 400
EXTENT 3250470.029539 5221162.578925 3942023.41747 6113902.660721
UNITS METERS
TRANSPARENT ON
#SHAPEPATH "Daten"
IMAGECOLOR 255 255 255
PROJECTION
"init=epsg:31467"
END
WEB
MINSCALE 100
MAXSCALE 8200000
IMAGEPATH '/srv/www/htdocs/mapserv_tmp/'
IMAGEURL '/mapserv_tmp/'
LOG '/srv/www/htdocs/anw1/mapserv_log.log'
END
LAYER
NAME "Kreise"
DATA "sde.rl_vg250_kreis,shape"
METADATA
LYRNAME "Kreis"
END
DEBUG ON
CONNECTIONTYPE SDE
#CONNECTION "wagis.ilmenau.baw.de,ol_wagisimp,wagisimp,usrID,usrPwd"
#CONNECTION
"wagis.ilmenau.baw.de:5150,ol_wagisimp,wagisimp,usrID,usrPwd"
#CONNECTION "wagis.ilmenau.baw.de,port:5150,wagisimp,usrID,usrPwd"
#CONNECTION "wagis.ilmenau.baw.de,5150,wagisimp,usrID,usrPwd"
CONNECTION "wagis,5150,wagisimp,usrID,usrPwd"
STATUS ON
TYPE POLYGON
PROJECTION
"init=epsg:4326"
END
CLASS
COLOR 230 230 230
OUTLINECOLOR 220 180 180
END
END
END
Thanks in advance
Norbert Thieme
Bundesanstalt für Wasserbau * FIT Ilmenau * Referat IT2
Am Ehrenberg 8 * 98693 Ilmenau * Germany
