[Mapserver-users] world files and tile indexing
Ed McNierney
ed at topozone.com
Sat May 1 13:39:07 EDT 2004
This is a multi-part message in MIME format.
------_=_NextPart_001_01C42FA3.3437712E
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
Antonio -
=20
Thanks - that is very helpful!
=20
Things seem fine, but you need to create georeference data for the
images in a way that can be used - the JPG files could have world files
(.JGW files) or the TIF files could have world files (.TFW) but you need
them. You need to create these world files. You should try to read the
coordinates from the shapefile (use shpdump) and you need to calculate
the values for the world files. With only three files you can
relatively easily do this by hand.
=20
The shapefile polygons should give you the upper-left corner coordinate
of each tile, and you should be able to calculate the size of each pixel
in X and Y units from the shapefile polygons and information about how
many pixels wide and high each image is (use tiffinfo).
=20
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242=20
_____ =20
From: Antonio Cosenza [mailto:antonio.cosenza at polito.it]=20
Sent: Saturday, May 01, 2004 6:18 AM
To: mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] world files and tile indexing
It would help if you could explain what you're trying to do! =20
ok, i'll try tou explain you my situation!
What
format are the raster files in now,=20
The raster files are in jpg format. They are a set of 3 tiles NOT
GEOREFERENCED (of course, they are jpg!). But, i have a shapefile,
called tile.shp (so, georeferenced) representing the footprints of the
tiles. In tile.shp, I created a field (Path) including the absoulte path
to tiff tiles on my disk (ex. /var/www/.....F4-C4.tif).Now, i converted
the jpg files in tiff files, without the world files. I use this mapfile
configuration:
LAYER
NAME "pannelli"
STATUS ON
TYPE RASTER
TILEINDEX "./tile.shp"
TILEITEM "Path"
END
I run maplab, but an error occurs: unable to open tiff files:
Description=09
Unable to open world file for reading. in
/maplab/htdocs/common/wrapper/drawmap.php=09
Failed to draw layer named 'pannelli'. in
So, i created some empty world files! This time, maplab runs without
error, but it doesn't show me the tiles. It shows me only a blank page.
Where is the problem?
and what geographic reference data
do you have for them (and in what format)?
=09
- Ed
=09
Ed McNierney
ed at topozone.com
(978) 251-4242 =20
=09
-----Original Message-----
Sent: Friday, April 30, 2004 5:43 AM
To: Ed McNierney; mapserver-users at lists.gis.umn.edu
=09
so, i need to convert the raster tiles in tiff format, without
world
files? Right?
=09
thanks
=09
Ed McNierney wrote:
=09
=20
Antonio -
=09
Yes, as long as the georeference information is there
for the tile=20
index to be created (and for the image to be rendered
properly). =20
GeoTIFFs can be used in a TILEINDEX layer without world
files.
=09
- Ed
=09
Ed McNierney
ed at topozone.com
(978) 251-4242
=09
Sent: Thursday, April 29, 2004 2:40 PM
Subject: [Mapserver-users] world files and tile indexing
=09
Hi everyvody,
is it possible to use tile indexing without world file?
=09
thanks
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
=09
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
=09
=09
=20
=09
=20
=09
=09
=09
=09
=20
Content-Type: text/html;
charset="us-ascii"
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD><TITLE></TITLE>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Dus-ascii">
<META content=3D"MSHTML 6.00.2800.1400" name=3DGENERATOR></HEAD>
<BODY text=3D#000000 bgColor=3D#ffffff>
<DIV dir=3Dltr align=3Dleft><SPAN class=3D456053617-01052004><FONT =
face=3DArial=20
color=3D#0000ff size=3D2>Antonio -</FONT></SPAN></DIV>
face=3DArial=20
color=3D#0000ff size=3D2></FONT></SPAN> </DIV>
face=3DArial=20
color=3D#0000ff size=3D2>Thanks - that is very =
helpful!</FONT></SPAN></DIV>
face=3DArial=20
face=3DArial=20
color=3D#0000ff size=3D2>Things seem fine, but you need to create =
georeference data=20
for the images in a way that can be used - the JPG files could have =
world files=20
(.JGW files) or the TIF files could have world files (.TFW) but you need =
them. You need to create these world files. You should try =
to read=20
the coordinates from the shapefile (use shpdump) and you need to =
calculate the=20
values for the world files. With only three files you can =
relatively=20
easily do this by hand.</FONT></SPAN></DIV>
face=3DArial=20
face=3DArial=20
color=3D#0000ff size=3D2>The shapefile polygons should give you the =
upper-left=20
corner coordinate of each tile, and you should be able to calculate the =
size of=20
each pixel in X and Y units from the shapefile polygons and information =
about=20
how many pixels wide and high each image is (use =
tiffinfo).</FONT></SPAN></DIV>
face=3DArial=20
<DIV dir=3Dltr align=3Dleft><SPAN =
class=3D456053617-01052004> <FONT=20
face=3DArial color=3D#0000ff size=3D2>- Ed</FONT></SPAN></DIV>
<P><FONT size=3D2>Ed McNierney<BR>President and Chief =
Mapmaker<BR>TopoZone.com /=20
Maps a la carte, Inc.<BR>73 Princeton Street, Suite 305<BR>North =
Chelmsford,=20
MA 01863<BR>ed at topozone.com<BR>(978) 251-4242 =
</FONT></P></SPAN></DIV><BR>
<DIV class=3DOutlookMessageHeader lang=3Den-us dir=3Dltr align=3Dleft>
<HR tabIndex=3D-1>
<FONT face=3DTahoma size=3D2><B>From:</B> Antonio Cosenza=20
[mailto:antonio.cosenza at polito.it] <BR><B>Sent:</B> Saturday, May 01, =
2004 6:18=20
AM<BR><B>To:</B> mapserver-users at lists.gis.umn.edu<BR><B>Subject:</B> =
Re:=20
[Mapserver-users] world files and tile indexing<BR></FONT><BR></DIV>
<DIV></DIV><BR>
<BLOCKQUOTE =
cite=3Dmid13858AA1A74F30419F319ACB66A9D1224E4426 at mercator.topozone.com=20
type=3D"cite"><PRE wrap=3D"">It would help if you could explain what =
you're trying to do! </PRE></BLOCKQUOTE>ok,=20
i'll try tou explain you my situation!<BR>
<BLOCKQUOTE =
type=3D"cite"><PRE wrap=3D"">What
format are the raster files in now, </PRE></BLOCKQUOTE>The raster files =
are in=20
jpg format. They are a set of 3 tiles NOT GEOREFERENCED (of =
course, they=20
are jpg!). But, i have a shapefile, called tile.shp (so, georeferenced)=20
representing the footprints of the tiles. In tile.shp, I created a =
field=20
(Path) including the absoulte path to tiff tiles on my disk (ex.=20
/var/www/.....F4-C4.tif).Now, i converted the jpg files in tiff =
files,=20
without the world files. I use this mapfile=20
configuration:<BR><BR> LAYER<BR> NAME=20
"pannelli"<BR> STATUS ON<BR> TYPE=20
RASTER<BR> TILEINDEX =
"./tile.shp"<BR> =20
TILEITEM "Path"<BR> END<BR><BR>I run maplab, but an error occurs: =
unable=20
to open tiff files:<BR><BR>
<TABLE cellSpacing=3D0 cellPadding=3D2 border=3D0>
<TBODY>
<TR>
<TD colSpan=3D2><FONT face=3DArial,Helvetica,sans-serif =
color=3D#000000=20
size=3D2>Description</FONT></TD></TR>
<TR>
<TD colSpan=3D2><FONT face=3DARIAL,Helvetica,sans-serif =
color=3D#ff3333=20
size=3D2>Unable to open world file for reading. in=20
/maplab/htdocs/common/wrapper/drawmap.php</FONT></TD></TR>
<TR>
color=3D#ff3333=20
size=3D2>Failed to draw layer named 'pannelli'. in=20
<TR>
color=3D#ff3333=20
<TR>
color=3D#ff3333=20
/maplab/htdocs/common/wrapper/drawmap.php</FONT></TD></TR></TBODY></TABLE=
><BR>So,=20
i created some empty world files! This time, maplab runs without error, =
but it=20
doesn't show me the tiles. It shows me only a blank page.<BR>Where is =
the=20
problem?<BR><BR><BR>
<BLOCKQUOTE =
type=3D"cite"><PRE wrap=3D"">and what geographic reference data
- Ed
Ed McNierney
<A class=3Dmoz-txt-link-abbreviated =
href=3D"mailto:ed at topozone.com">ed at topozone.com</A>
(978) 251-4242 =20
From: Antonio Cosenza [<A class=3Dmoz-txt-link-freetext =
href=3D"mailto:antonio.cosenza at polito.it">mailto:antonio.cosenza at polito.i=
t</A>]=20
To: Ed McNierney; <A class=3Dmoz-txt-link-abbreviated =
href=3D"mailto:mapserver-users at lists.gis.umn.edu">mapserver-users at lists.g=
is.umn.edu</A>
so, i need to convert the raster tiles in tiff format, without world
files? Right?
thanks
Ed McNierney wrote:
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Antonio -
Yes, as long as the georeference information is there for the tile=20
index to be created (and for the image to be rendered properly). =20
GeoTIFFs can be used in a TILEINDEX layer without world files.
- Ed
Ed McNierney
(978) 251-4242
t</A>]
To: <A class=3Dmoz-txt-link-abbreviated =
is.umn.edu</A>
Hi everyvody,
thanks
href=3D"mailto:Mapserver-users at lists.gis.umn.edu">Mapserver-users at lists.g=
is.umn.edu</A>
href=3D"http://lists.gis.umn.edu/mailman/listinfo/mapserver-users">http:/=
/lists.gis.umn.edu/mailman/listinfo/mapserver-users</A>
=20
</PRE></BLOCKQUOTE><PRE wrap=3D""><!---->
is.umn.edu</A>
</PRE></BLOCKQUOTE><BR></BODY></HTML>
------_=_NextPart_001_01C42FA3.3437712E--
