[Mapserver-users] mapserver on mandrake
Paco Regodon
mapserver at meteologica.es
Mon May 3 11:26:14 EDT 2004
Have you tried the demo?
mapserver-demo-3.5-2mdk
you should be able to test it on
http://[your_host]/mapserver/itasca/index.html
Paco
On Monday 03 May 2004 15:28, Sébastien DUBOIS wrote:
> hello,
> I have used "urpmi" to install mapserver under Mandrake9.2
> So like Paco Regodon i've got the mapserver-4.0-1mdk, the rpm package from
> Mandrake
> I install apache by the same way (urpmi apache) then i made
> > apachectl start
> is that enough to start apache?
> mapserv is in /var/www/
> bu
> [root at sx-dubois sbin]# which apachectl
> /usr/sbin/apachectl
> so mapserv and apache are not in the same directory !!!
> I verified carefully that all the requires were installed
> Requires
> * webserver
> * libc.so.6
> * libcrypto.so.0.9.7
> * libcurl.so.2
> * libdl.so.2
> * libfreetype.so.6
> * libgd.so.2
> * libgdal.1.1.so
> * libjpeg.so.62
> * libm.so.6
> * libpng.so.3
> * libproj.so.0
> * libssl.so.0.9.7
> * libstdc++.so.5
> * libtiff.so.3
> * libz.so.1
> but when I test on my favourite browser:
> http://sx-dubois@rd.francetelecom.com/var/www/cgi-bin/mapserv
> I can red:
> Warning: Failed opening '../../../fr/navigation/cadres.php' for inclusion
> (include_path='.:/usr/local/lib/php') in /export/WWW/fr/navigation/bar.php
> on line 40
> Warning: Failed opening '../../../fr/navigation/ftbar.php' for inclusion
> on line 41
> Warning: Failed opening '../../../fr/navigation/rubriques.php' for
> inclusion (include_path='.:/usr/local/lib/php') in
> /export/WWW/fr/navigation/bar.php on line 42
> Fatal error: Call to undefined function: rd_head() in
> /export/WWW/404.html.php on line 27
> Have you got a explanation for that?
> thanks in advance for the time you spend to help me...
