[Mapserver-users] Lines between points and polygon colors
{Scanned} {Scanned}
Siki Zoltan
siki at agt.bme.hu
Tue May 4 04:42:48 EDT 2004
On Mon, 3 May 2004, K Resellmo wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi,
> I have two questions about MapServer features:
> 1. Is it possible to use the MapServer symbol capabilities to draw lines
> between points? I have several sets of points that I would like to display
> using both a graphic to mark the point, and a line to connect the points.
I think not, you need two separate layer/shape to display points and
lines. The graphical object type is defined in the GIS data set.
> 2. Can I display polygons in different colors? (like a political map with
> different colors for different countries)
Yes, you can create tematic maps based on attribute data.
See CLASS in map file reference.
Bye
Zoltan
> Thanks for your time!
> Kris
> -----BEGIN PGP SIGNATURE-----
> Version: PGP 8.0.2
> iQA/AwUBQJb8Kp4XWyzLnsoNEQJe8QCfcznektK5ltIgL9EnBBiBKj62isgAoNUY
> bkWw9Bc97Xwdk2e+dXWNp1jf
> =cBPQ
> -----END PGP SIGNATURE-----
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
