[Mapserver-users] drawing layers with labels using php
Norbert Thieme
norbert.thieme at ilmenau.baw.de
Tue May 4 06:15:12 EDT 2004
publiek at home.nl schrieb:
> Hello,
> How do i draw layers that consist of labels?
> I get a blank image.
> Using php mapscript functions draw, saveWebimage.
> What in the world am i missing?
> Thanks.
> Marcel
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
it would help if you could send your mapfile or parts of it the next
time. However this thing work in general. You can have a look at my
layer definition from a simple .shp file.
LAYER
NAME "Ortslage"
DATA "ortslage"
STATUS DEFAULT
TYPE POLYGON
#TYPE ANNOTATION # you can use this instead but there could
be something wrong in the mapscript -> all labels get drawn in my case
PROJECTION
"init=epsg:31467"
END
LABELITEM 'NAME'
CLASS
# COLOR 232 232 232
# OUTLINECOLOR 32 32 32
LABEL
COLOR 100 100 100
#BACKGROUNDCOLOR 220 220 190
SHADOWCOLOR 250 250 220
SHADOWSIZE 1 1
TYPE BITMAP
SIZE MEDIUM
BUFFER 15
END
END
END
Did you get a correct image from another layer?
BTW there can also be a problem with your PROJECTION definitions. In
most cases this is the reason for blank images.
Regards,
Norbert
