[Mapserver-users] Using itasci rubber band in php
Norbert Thieme
norbert.thieme at ilmenau.baw.de
Tue May 4 06:38:51 EDT 2004
publiek at home.nl schrieb:
> I am trying to rewrite the itasca example (javascript with dhtml rubber band box) to php.
> What i want is to let the dbox javascript thing communicate with my php functions.
> Am i doing something that is possible? Or should i use something else for the rubber band selection?
> Any ideas are welcome.
> Thanks,
> Marcel
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Yes,
you can do that. Just make two inputs with a name in your form in the
php file (e.g. <input .... name=javasX>).
I don't know what your does exactly but you can asign the Values from
your coordinates to the html/php inputs (e.g.
document.yourform.javasX.value = someXcoordinate). Notice that you
should know what coordinates you get from the script (pixel, position of
start point).
If the from gets submitted you can use this in php script. If your form
uses POST then it could look like:
if (isset($HTTP_POST_VARS["javasX"]))
$click_x = $HTTP_POST_VARS["javasX"];
Now you can use this coordinates in php and do what you want to do.
Regards,
Norbert
