[Mapserver-users] Query
Andreas Schaumberger
schaumberger at gmx.net
Tue May 4 16:42:31 EDT 2004
This is a multi-part message in MIME format.
------=_NextPart_000_0001_01C43229.1C1BAC00
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
Hello!
As a student I'm starting to work with MapServer on a project this term. =
Our
job is to add our own attributes to an existing shape-file. These =
attributes
should be stored in a SQL-Database (postgreSQL - postgis) as a relation =
to
the attributes of the shape-file. The user should click on a feature in =
the
map and get the list of attributes. Now, the user should be able to add =
his
attributes. So far, the implementation is quite clear but we still have =
a
missing link.=20
=20
Is there any way to get the key (or other) attribute of the feature =
which is
clicked on? We need this attribute as a variable in our java servlet for
running the database application. We would like to use only the CGI
MapServer.
=20
Thanks for help
Andreas
=20
=20
=20
Content-Type: text/html;
charset="us-ascii"
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<TITLE>Nachricht</TITLE>
<META content=3D"MSHTML 6.00.2800.1400" name=3DGENERATOR></HEAD>
<BODY>
<DIV><FONT face=3DArial size=3D2><SPAN=20
class=3D718475419-04052004>Hello!</SPAN></FONT></DIV>
<DIV><FONT face=3DArial size=3D2><SPAN class=3D718475419-04052004>
<P class=3DMsoNormal style=3D"MARGIN: 0cm 0cm 0pt"><SPAN lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-ansi-language: =
EN-GB">As a=20
student I'm starting to work with MapServer on a project this term. Our =
job is=20
to add our own attributes to an existing shape-file. These attributes =
should be=20
stored in a SQL-Database (postgreSQL – postgis) as a relation to =
the attributes=20
of the shape-file. The user should click on a feature in the map and get =
the=20
list of attributes. Now, the user should be able to add his attributes. =
So far,=20
the implementation is quite clear but we still have a missing link.=20
<?xml:namespace prefix =3D o ns =3D =
"urn:schemas-microsoft-com:office:office"=20
/><o:p></o:p></SPAN></P>
EN-GB"><o:p> </o:p></SPAN></P>
EN-GB">Is there=20
any way to get the key (or other) attribute of the feature which is =
clicked on?=20
We need this attribute as a variable in our java servlet for running the =
database application. We would like to use only the CGI=20
MapServer.<o:p></o:p></SPAN></P>
EN-GB">Thanks for=20
help</SPAN></P>
EN-GB"><o:p><SPAN=20
class=3D718475419-04052004>Andreas</SPAN></o:p></SPAN></P>
style=3D"mso-ansi-language: EN-GB"><o:p><FONT face=3D"Times New Roman"=20
size=3D3> </FONT></o:p></SPAN></P></SPAN></FONT></DIV>
<DIV> </DIV></BODY></HTML>
------=_NextPart_000_0001_01C43229.1C1BAC00--
