[Mapserver-users] Which is better: PHPMapScript query engine or PHP dBase functions?
Eduardo Patto Kanegae
eduardo at consultoria.eti.br
Wed May 5 12:38:17 EDT 2004
Thanks for all replies.
By this time I decided to use the MapScript query engine because of portability: today my geodatabase is ShapeFiles, but tomorrow it could be PostGIS, MyGIS, ... so, I prefered Mapscript because I will be able to write only one code and query routines will be same.
best.
http://www.consultoria.eti.br
UIN: 303747254
I Encontro Nacional de Usuários MapServer - http://mapserver.cttmar.univali.br/encontro2004
Projeto MapServer Brasil - http://mapserver.cttmar.univali.br
***Fim da Mensagem / End of Message ***
On Wed, 5 May 2004 09:02:39 -0700, "Ryan, Adam" <ARyan at co.linn.or.us> escreveu:
> De: "Ryan, Adam" <ARyan at co.linn.or.us>
> Data: Wed, 5 May 2004 09:02:39 -0700
> Para: norbert.thieme at ilmenau.baw.de, eduardo at consultoria.eti.br
> Assunto: RE: [Mapserver-users] Which is better: PHPMapScript query engine or PHP dBase functions?
> Norbert writes...
> >//this first part is a separate form but it should work also in one
> >$recs = dbase_numrecords($dbi);//opened dbf
> >$q_index_array = array();//save the indexes from the .dbf in this array
> >for ($i = 1; $i < $recs; $i++)
> > $s_field = dbase_get_record_with_names($dbi, ($i + 1));
> > if (!(strpos(strtolower($s_field[$qitem]), strtolower($qstring))) ===
> >false))
> > $q_index_array[] = $i;
> This is too slow and limited. You should try the ODBC functions in PHP.
> You can run SQL queries on a dbf file by regarding the directory in which
> the file resides as the database. This gives you all the flexibility of SQL
> statements.
> >for ($i = 0; $i < count($q_index_array); $i++)
> > if (@$map->queryByIndex($qlayer->index, 0, $q_index_array[$i],
> >MS_FALSE) == MS_SUCCESS)
> > $q_img = $map->drawquery();
> > $q_path = $q_img->savewebimage();
> > echo "<img src=".$q_path.">";
> I'm not sure I get this code. Seems like your stepping through a list of
> index numbers, setting them with queryByIndex, but then drawing the map
> after every index? I don't get it. The map should be drawn after iterating
> through the whole array, no?
> Anyway, I think the two routines above are flawed in that the index values
> in the shapefile and in the dBase file and not be assumed to be equal. If
> I'm wrong about this I hope someone will correct me. They usually are the
> same, but the whole point of the *.shx file is to reconcile differences in
> the indexing. So you're taking the indexing from the dBase and applying
> this to the shapefile and I think on careful examination on some of larger
> file sets you'll find that what you're displaying textually and graphically
> don't match.
> By the way, I've found that queryByIndex is way too slow. It works fine for
> a small set of records, but with large selection sets I've found it's too
> slow. I use save and load query as much as I can.
> Adam
> -----Original Message-----
> From: Norbert Thieme [mailto:norbert.thieme at ilmenau.baw.de]
> Sent: Tuesday, May 04, 2004 1:20 AM
> To: Ryan, Adam; eduardo at consultoria.eti.br
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] Which is better: PHPMapScript query engine or
> Ryan, Adam schrieb:
> > Eduardo,
> > I might be off track but...
> > I thought about this myself. In order to display the result shapes
> > you need to have a query result either from doing the query in
> > mapscript or loading a saved query file. The former defeats the point
> > of querying the dBase since you're duplicating your steps, and the
> > later requires you to manually build a query file but you can't do
> > that unless you can get at the dBase record - shapefile index
> > relationship which I don't know how to do.
> > Again, I may be off track, but querying the dBase file may not be
> > feasible.
> > Adam
> > From: Eduardo Patto Kanegae [mailto:eduardo at consultoria.eti.br]
> > Sent: Monday, May 03, 2004 11:06 AM
> > To: mapserver-users at lists.gis.umn.edu
> > Subject: [Mapserver-users] Which is better: PHPMapScript query engine or
> PHP
> > dBase functions?
> > I have a mapserver+php+mapscript that will query on a shapefile
> > database on a single layer, through its atributes.
> > The system will give as result a set of items on a result list as a
> > first step. Then as a second step a map displaying these results
> > should be given.
> > my doubt is: to create this result list which will be best strategy:
> > - use PHPMapScript to query against the mapfile ?
> > or
> > - simply use PHP dBase functions to query against dBase files of the
> > mapfile?
> > which one is the best/fastest alternative?
> > best regards.
> > UIN: 303747254
> > Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> Hi,
> I think you can use both. If you use querybyattributes then you use the
> ability of the mapserver to search only in your current extent. But you
> have the problem that the qstring must be exactly the same (case
> sensitive). If anyone knows a way (without much own code) to search with
> the mapserver after only parts of words and case ignoring it would be
> great if he shares it. Because that would work with all kinds of types
> of data not only for shapes.
> For the other case I use the following code to search the way described
> above - I cut it a bit:
> //this first part is a seperate form but it should work also in one
> false))
> //second part - map
> Regards,
> Norbert
