[Mapserver-users] PHP/Mapscript - Point symbols appearing without color
Kasey Kirkham
kasey at inexo.com
Wed May 5 15:59:39 EDT 2004
Hello all,
We are noticing a strange problem with pixmap symbol layers. At certain
zoom levels the symbols will appear with the correct color. At other
levels the color will disappear, leaving the symbol black for several
zoom levels, only to reappear upon zooming in a few levels further. The
pixmaps are the standard colored dots that are packaged with Mapserver.
Here are the relevant bits:
// MAPFILE
LAYER
NAME "point_mapping-green"
TYPE POINT
STATUS ON
# CLASS object
CLASS
NAME "points_green"
SYMBOL "gps_coordinate-green"
COLOR 255 0 0
# LABEL object
LABEL
POSITION CC
SIZE TINY
MINDISTANCE 400
MINFEATURESIZE 5
COLOR 255 255 255
PARTIALS FALSE
END
END
END
// SYMBOLSET file
Symbol
Name 'gps_coordinate-green'
Type PIXMAP
IMAGE "../markers/green8.png"
Transparent 4
END
// PHP Code
foreach($point_array as $arPoints) {
$pointObj_coord1 = ms_newPointObj(); // get a
point object
// set the X and Y
$coord_1_x = $arPoints["longitude"];
$coord_1_y = $arPoints["latitude"];
$pointObj_coord1->setXY($coord_1_x, $coord_1_y);
// get_unit_symbol would return
'point_mapping-green', in this case
$layerObj_imageSymbol =
$map->getLayerByName($currObjUnit->get_unit_symbol());
// draw the point
$pointObj_coord1->draw($map,
$layerObj_imageSymbol, $image, 0, '');
Has anyone ever seen this type of behavior before?
Thanks for your help,
Kasey
