[Mapserver-users] GetLegendGraphic questions
Emil Zegers
EZS at DeStraat.NL
Fri May 7 11:38:10 EDT 2004
Hello Bart,
Don't know if this is the cause but when you look in maplegend.c msDrawLegendIcon is called in the else part if class is NULL (if class is NULL all classes should be drawn):
// Call drawLegendIcon with destination (0, 0)
// Return an empty image if lp==NULL || class=NULL
//(If class is NULL draw the legend for all classes. Modifications done
// Fev 2004 by AY)
if (lp) {
msClearLayerPenValues(lp); // just in case the mapfile has already been processed
if (class) {
msDrawLegendIcon(map, lp, class, width, height, image->img.gd, 0, 0);
else {
for (i=0; i<lp->numclasses; i++) {
msDrawLegendIcon(map, lp, &lp->class[i], width, height, image->img.gd, 0, 0);
But doesn't it clip every image on top on the former one like this with dstX en dstY set to 0?
Regards,
Emil Zegers
>>> <bartvde at xs4all.nl> 05/07/04 01:38pm >>>
Hi list,
I have some questions about the GetLegendGraphic operation in Mapserver.
I have a layer in my MAP file which has 5 classes, but when performing a
GetLegendGraphic request I only get an image of the last class defined.
Should I not get an image of all classes?
Also, how do you get the "text labels" for the specific classes, e.g.
"0-20%" next to the symbols?
Maybe I am missing something in my LAYER definition?
This is the request I am using:
http://myserver/cgi-bin/mapserv.exe?map=/ms4w/apps/zulte/map/zulte_server..map&layer=kwelder_2000&version=1.1.1&request=GetLegendGraphic&format=image/png
This is my LAYER definition:
LAYER
METADATA
WMS_TITLE "2000_kwelder"
WFS_TITLE "2000_kwelder"
WMS_ABSTRACT "2000_kwelder"
WMS_SRS "epsg:28992"
END
NAME "kwelder_2000"
CONNECTIONTYPE OGR
TILEINDEX "2000.shp"
SIZEUNITS PIXELS
STATUS ON
TOLERANCE 3
TOLERANCEUNITS PIXELS
TYPE POLYGON
DUMP TRUE
TEMPLATE "blank.html"
UNITS METERS
CLASSITEM "Kwelder_to"
CLASS
EXPRESSION (([Kwelder_to] > 0) AND ([Kwelder_to] <= 20))
NAME "0-20%"
COLOR 254 255 212
END
CLASS
EXPRESSION (([Kwelder_to] > 20) AND ([Kwelder_to] <= 40))
NAME "21-40%"
COLOR 255 218 143
END
CLASS
EXPRESSION (([Kwelder_to] > 40) AND ([Kwelder_to] <= 60))
NAME "41-60%"
COLOR 255 151 41
END
CLASS
EXPRESSION (([Kwelder_to] > 60) AND ([Kwelder_to] <= 80))
NAME "61-80%"
COLOR 217 95 13
END
CLASS
EXPRESSION (([Kwelder_to] > 80) AND ([Kwelder_to] <= 100))
NAME "81-100%"
COLOR 153 54 5
END
END
Thanks in advance for any info on this subject.
Best regards,
Bart
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
__________
VChecked
______________________________________________________
This message has been checked for all known viruses
