[Mapserver-users] SWF problem
GIRAUD Pierre
pierre.giraud3 at free.fr
Sun May 9 13:04:37 EDT 2004
--------------090904060408050504020502
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Content-Transfer-Encoding: 8bit
Just try to output your map in multiple movies ("OUTPUT_MOVIE=MULTIPLE").
I expect this will not return fatal error but one swf for each layer in
your mapfile. Hope this works.
I don't even know why single output crashes. Is it due to ming library
or mapserver ?
If you are able with this method to generate movies, you'll just have to
redefined your Flash app to load each movie individualy.
I didn't work on this a lot but I think this might be a good way to
built a flash interface. I mean, layers may be hidden or shown
individualy easily and other great stuffs could be imagined.
It would also be great to have examples or experience returns from
people who succesfully explored this mapserver output possibility.
Regards.
Pierre GIRAUD
Hau Lu a écrit:
> Dear List user:
> I'm trying to use Mapserver (using the Windows binary
> ms402_png_pg.zip provided on the mapserver download site which should
> support SWF output) to output swf files that I can load from a Flash
> app ( using loadMovie(..) function).
> part of my php code looks like this:
> ......Initialize $map object
> $map->selectOutputFormat("SWF");
> $image = $map->draw();
> $image_url=$map->saveWebImage(); // error occurs here
> .....output the $image_url var to Flash app
> and the map file looks like this (it's actually one of the example map
> files from the tutorial):
> MAP
> IMAGETYPE JPEG
> INTERLACE OFF
> EXTENT 201621.496941 -294488.284025 1425518.020722 498254.511514
> SIZE 400 300
> SHAPEPATH "data"
> IMAGECOLOR 255 255 255
> OUTPUTFORMAT
> NAME swf
> MIMETYPE "application/x-shockwave-flash"
> DRIVER swf
> IMAGEMODE PC256
> FORMATOPTION "OUTPUT_MOVIE=SINGLE"
> END
> WEB
> IMAGEPATH "C:/Apache/htdocs/tmp/"
> IMAGEURL "/tmp/"
> MAXSCALE 150000000
> MINSCALE 200
> END
> PROJECTION
> "proj=laea"
> "ellps=clrk66"
> "lat_0=45"
> "lon_0=-100"
> END
> # Start of LAYER DEFINITIONS ---------------------------------------------
> LAYER # States polygon layer begins here
> NAME states_poly
> DATA states_ugl
> STATUS DEFAULT
> TYPE POLYGON
> PROJECTION
> "init=epsg:4326"
> END
> CLASS
> COLOR 232 232 232
> END
> END # States polygon layer ends here
> LAYER # States line layer begins here
> NAME states_line
> DATA states_ugl
> STATUS DEFAULT
> TYPE LINE
> PROJECTION
> "init=epsg:4326"
> END
> CLASS
> COLOR 32 32 32
> END
> END # States line layer ends here
> # End of LAYER DEFINITIONS -------------------------------
> END # end of map file
> I get the following error :
> "PHP Fatal error: Failed writing image to
> C:/Apache/htdocs/tmp/108411324937081.swf ....."
> when the Flash app tries to call the php program, the SWF file is
> created with properly content (viewable in a stanalone flash player)
> in the designated directory but the PHP program just stopped without
> responding to the Flash app. Using the same code, I can output JPEG
> images to the Flash app without any problem. I've also tried to output
> the SWF from mapserv.exe using CGI calls but that also failed.
> Searching through the list archive, I found some people having the
> same problem that I have but there's no answer. I've read the user doc
> at
> http://www2.dmsolutions.ca/mapserver/dl/FlashMapserverUserDoc.html but
> don't have a clue on what I did wrong, can anybody give me a hand here?
> Best Regards,
> Hau
Content-Type: text/html; charset=us-ascii
Content-Transfer-Encoding: 7bit
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<title></title>
</head>
<body>
Just try to output your map in multiple movies ("OUTPUT_MOVIE=MULTIPLE").<br>
I expect this will not return fatal error but one swf for each layer in your
mapfile. Hope this works.<br>
I don't even know why single output crashes. Is it due to ming library or
mapserver ?<br>
<br>
redefined your Flash app to load each movie individualy.<br>
I didn't work on this a lot but I think this might be a good way to built
a flash interface. I mean, layers may be hidden or shown individualy easily
and other great stuffs could be imagined.<br>
<br>
It would also be great to have examples or experience returns from people
who succesfully explored this mapserver output possibility.<br>
<br>
Regards.<br>
<br>
Pierre GIRAUD<br>
<br>
Hau Lu a écrit:<br>
<blockquote type="cite" cite="mid200405091503.XAA20722 at msr38.hinet.net">
<meta http-equiv="Content-Type" content="text/html; ">
<meta content="MSHTML 6.00.2800.1400" name="GENERATOR">
<div><font face="新細明體" size="2"><span class="212195413-09052004">Dear List
user:</span></font></div>
<div><font face="新細明體" size="2"><span class="212195413-09052004"></span></font> </div>
<div><font face="新細明體" size="2"><span class="212195413-09052004"> I'm
trying to use Mapserver (using the Windows binary ms402_png_pg.zip provided
on the mapserver download site which should support SWF output) to output
swf files that I can load from a Flash app ( using loadMovie(..) function).</span></font></div>
<div><font face="新細明體" size="2"><span class="212195413-09052004">part of
my php code looks like this:</span></font></div>
<div><font face="新細明體" size="2"><span class="212195413-09052004">......Initialize
$map object</span></font></div>
<div><font face="新細明體" size="2"><span class="212195413-09052004">$map->selectOutputFormat("SWF");</span></font><font
face="新細明體" size="2"><span class="212195413-09052004"><br>
$image = $map->draw();<br>
$image_url=$map->saveWebImage(); // error occurs here</span></font></div>
<div><font face="新細明體" size="2"><span class="212195413-09052004">.....output
the $image_url var to Flash app</span></font></div>
<div><font face="新細明體" size="2"><span class="212195413-09052004">and the
map file looks like this (it's actually one of the example map files from
the tutorial):</span></font></div>
<div><font face="新細明體" size="2"><span class="212195413-09052004">MAP<br>
IMAGETYPE JPEG<br>
INTERLACE OFF<br>
EXTENT 201621.496941 -294488.284025 1425518.020722 498254.511514<br>
SIZE 400 300<br>
SHAPEPATH "data"<br>
IMAGECOLOR 255 255 255</span></font></div>
<div> </div>
<div><font face="新細明體" size="2"><span class="212195413-09052004">OUTPUTFORMAT
<br>
NAME swf <br>
MIMETYPE "application/x-shockwave-flash" <br>
DRIVER swf <br>
IMAGEMODE PC256 <br>
FORMATOPTION "OUTPUT_MOVIE=SINGLE" <br>
END </span></font></div>
<div> </div>
<div><font face="新細明體" size="2"><span class="212195413-09052004">WEB<br>
IMAGEPATH "C:/Apache/htdocs/tmp/"<br>
IMAGEURL "/tmp/"<br>
MAXSCALE 150000000<br>
MINSCALE 200<br>
END</span></font></div>
<div> </div>
<div><font face="新細明體" size="2"><span class="212195413-09052004">PROJECTION<br>
"proj=laea"<br>
"ellps=clrk66"<br>
"lat_0=45"<br>
"lon_0=-100"<br>
<div> </div>
<div><font face="新細明體" size="2"><span class="212195413-09052004"># Start
of LAYER DEFINITIONS ---------------------------------------------<br>
LAYER # States polygon layer begins here<br>
NAME states_poly<br>
DATA states_ugl<br>
STATUS DEFAULT<br>
TYPE POLYGON</span></font></div>
<div> </div>
<div><font face="新細明體" size="2"><span class="212195413-09052004"> PROJECTION<br>
"init=epsg:4326"<br>
<div> </div>
<div><font face="新細明體" size="2"><span class="212195413-09052004"> CLASS<br>
COLOR 232 232 232<br>
END<br>
END # States polygon layer ends here</span></font></div>
<div> </div>
<div><font face="新細明體" size="2"><span class="212195413-09052004">LAYER
# States line layer begins here<br>
NAME states_line<br>
DATA states_ugl<br>
STATUS DEFAULT<br>
TYPE LINE</span></font></div>
<div> </div>
<div> </div>
COLOR 32 32 32<br>
END<br>
END # States line layer ends here<br>
# End of LAYER DEFINITIONS -------------------------------</span></font></div>
<div> </div>
<div><font face="新細明體" size="2"><span class="212195413-09052004">END #
end of map file<br>
<div><font face="新細明體" size="2"><span class="212195413-09052004"></span></font><font
<div><font face="新細明體" size="2"><span class="212195413-09052004">I get
the following error :</span></font></div>
<div><font face="新細明體" size="2"><span class="212195413-09052004"> "</span></font><font
face="新細明體" size="2"><span class="212195413-09052004"><font size="3"><font
size="2">PHP Fatal error: Failed writing image to C:/Apache/htdocs/tmp/108411324937081.swf
.....</font></font><font size="2">"</font></span></font></div>
face="新細明體" size="2"><span class="212195413-09052004"><font size="2">when
the Flash app tries to call the php program, the SWF file is created with
properly content (viewable in a stanalone flash player) in the designated
directory but the PHP program just stopped without responding to the Flash
app. Using the same code, I can output JPEG images to the Flash app without
any problem. I've also tried to output the SWF from mapserv.exe using CGI
calls but that also failed.</font></span></font></div>
face="新細明體" size="2"><span class="212195413-09052004"><font size="2">Searching
through the list archive, I found some people having the same problem that
I have but there's no answer. I've read the user doc at <a
href="http://www2.dmsolutions.ca/mapserver/dl/FlashMapserverUserDoc.html">http://www2.dmsolutions.ca/mapserver/dl/FlashMapserverUserDoc.html</a> but
don't have a clue on what I did wrong, can anybody give me a hand here?</font></span></font></div>
<div><font face="新細明體" size="2"><span class="212195413-09052004">Best Regards,</span></font></div>
<div><font face="新細明體" size="2"><span class="212195413-09052004">Hau</span></font></div>
</blockquote>
<br>
</body>
</html>
--------------090904060408050504020502--
