[Mapserver-users] Installation problem
Daniel Morissette
dmorissette at dmsolutions.ca
Tue May 11 11:43:12 EDT 2004
Andrea Rossi wrote:
> Hello.
> I am trying to install Mapserver-4.0.2 in a PC with
> this settings:
> Redhat 9
> Postgresql 7.3.4
> Postgis
> php 4.3.5
> When i do configure everytng is OK but when I do the
> make command I have this errors with php.
> What could be the problem?
> Thank you.
> cd mapscript/php3; make; cd ../..
> make[1]: Entering directory
> `/usr/local/src/mapserver-4.0.2/mapscript/php3'
> gcc -fPIC -O2 -Wall -DCOMPILE_DL=1 -DPHP4
> -DUSE_WMS_SVR -DUSE_POSTGIS -DUSE_GDAL -DUSE_OGR
> -DUSE_THREAD -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_PDF
> -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT
> -DUSE_JPEG -I/usr/local/src/mapserver-4.0.2
> -I/usr/include -I/usr/local/include
> -I/usr/local/include -I/usr/local/include
> -I/usr/local/include/php/main
> -I/usr/local/include/php/main/dl
> -I/usr/local/include/php/main/main
> -I/usr/local/include/php/main/Zend
> -I/usr/local/include/php/main/include
> -I/usr/local/include/php/main/TSRM -c -o
> php_mapscript_util.o php_mapscript_util.c
> In file included from php_mapscript_util.h:58,
> from php_mapscript_util.c:101:
> /usr/local/include/php/main/php.h:34:18: zend.h: No
> such file or directory
Did you use --with-php=/usr/local/include/php/main/ in the configure
command?
Try using --with-php=/usr/local, that should work with v4.0.2 and 4.2
If you could please file a bug in the MapServer bugzilla with the exact
configure command that you used, and information about the location of
your installed PHP then we could fix the configure script to make it
more robust and prevent that case from happening.
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
