[Mapserver-users] Virtual polygon problem!!
    Gijs Epping
    mapserver at gijs.com
    Wed May 12 04:34:45 PDT 2004
This is a multi-part message in MIME format.
------=_NextPart_000_0001_01C43825.E3C7BD00
Content-Type: text/plain;
	charset="Windows-1252"
Content-Transfer-Encoding: 7bit
Hello,
We are creating a polygon with the following code
function addPolygon($style)
global $gpoMap;
$style->color->setRGB(255, 0, 255);
$style->outlinecolor->setRGB(255, 0, 0);
$shp = ms_newShapeObj($this->type);
$line = ms_newLineObj();
$point = ms_newPointObj();
for($i=0; $i<count($this->coordinates); $i++)
 if($i==0)
 $line->addXY($this->coordinates[$i]->x, $this->coordinates[$i]->y);
 $shp->add($line);
 return $shp;
after this the polygon is added with $layer->addFeature($shp);
Now the weird thing is that if you zoom in, and a corner point from a
polygon (a square for example) drops next to the extend of the map the
square becomes I triangle. So the corner points next to the map extend
are cut off.
I did send some examples that you can see what is happening!!!!
Is there a solution that it will draw the polygons correct
Thanks in advance
Gijs
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.678 / Virus Database: 440 - Release Date: 6-5-2004
Content-Type: image/gif;
	name="polygon2.gif"
Content-Transfer-Encoding: base64
Content-Disposition: attachment;
	filename="polygon2.gif"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	name="polygon1.gif"
	filename="polygon1.gif"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==
------=_NextPart_000_0001_01C43825.E3C7BD00--
More information about the MapServer-users
