[Mapserver-users] Installation problem
Andrea Rossi
il_vikingo at yahoo.com
Wed May 12 09:23:42 EDT 2004
If I try you solution I get this message:
checking for location of config.h or php_config.h...
configure: error:
!!! Could not find config.h or php_config.h in
/usr/local. !!!
!!! Has PHP been configured yet?
--- Daniel Morissette <dmorissette at dmsolutions.ca>
wrote:
> Andrea Rossi wrote:
> > Hello.
> > I am trying to install Mapserver-4.0.2 in a PC
> with
> > this settings:
> > Redhat 9
> > Postgresql 7.3.4
> > Postgis
> > php 4.3.5
> > When i do configure everytng is OK but when I do
> the
> > make command I have this errors with php.
> > What could be the problem?
> > Thank you.
> > cd mapscript/php3; make; cd ../..
> > make[1]: Entering directory
> > `/usr/local/src/mapserver-4.0.2/mapscript/php3'
> > gcc -fPIC -O2 -Wall -DCOMPILE_DL=1 -DPHP4
> > -DUSE_WMS_SVR -DUSE_POSTGIS -DUSE_GDAL
> -DUSE_OGR
> > -DUSE_THREAD -DUSE_PROJ -DUSE_PROJ_API_H
> -DUSE_PDF
> > -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP
> -DUSE_GD_FT
> > -DUSE_JPEG -I/usr/local/src/mapserver-4.0.2
> > -I/usr/include -I/usr/local/include
> > -I/usr/local/include -I/usr/local/include
> > -I/usr/local/include/php/main
> > -I/usr/local/include/php/main/dl
> > -I/usr/local/include/php/main/main
> > -I/usr/local/include/php/main/Zend
> > -I/usr/local/include/php/main/include
> > -I/usr/local/include/php/main/TSRM -c -o
> > php_mapscript_util.o php_mapscript_util.c
> > In file included from php_mapscript_util.h:58,
> > from php_mapscript_util.c:101:
> > /usr/local/include/php/main/php.h:34:18: zend.h:
> No
> > such file or directory
> Did you use --with-php=/usr/local/include/php/main/
> in the configure
> command?
> Try using --with-php=/usr/local, that should work
> with v4.0.2 and 4.2
> If you could please file a bug in the MapServer
> bugzilla with the exact
> configure command that you used, and information
> about the location of
> your installed PHP then we could fix the configure
> script to make it
> more robust and prevent that case from happening.
> Daniel
> Daniel Morissette
> DM Solutions Group
> http://www.dmsolutions.ca/
__________________________________
Do you Yahoo!?
Yahoo! Movies - Buy advance tickets for 'Shrek 2'
http://movies.yahoo.com/showtimes/movie?mid=1808405861
