[Mapserver-users] postgis and drawquery failing
Daniel Morissette
dmorissette at dmsolutions.ca
Wed May 12 17:10:11 EDT 2004
AARON KONING wrote:
> Hello again list,
> So my problem has to do with postgis datasets again. If I do a $map->drawQuery() when more than one feature has been found I always get a postgis error:
> Warning: [MapServer Error]: msPOSTGISLayerGetShape(): Error executing POSTGIS SQL statement (in FETCH ALL): DECLARE mycursor BINARY CURSOR FOR SELECT asbinary(force_collection(force_2d(the_geom)),'NDR') from public.ipln_bc AS foo WHERE oid = 23234
> -ERROR: cursor "mycursor" already exists
> If only one feature is found, then no problem it shows up in yellow (my highlight color) every time.
> I've added oid and gist indexing, done VACUUM ANALYZE, done SELECT UPDATE_GEOMETRY_STATS() and no change has occurred.
> mapserver version: 4.0.1
> postgis version: 0.8.0
> postgresql version: 7.4
> Any suggestions or should I file a bug report?
I'd suggest that you try version 4.0.2, it contains the following change:
- Copied 4.1 mappostgis.c back with changes for pg7.4 support, error
reporting, etc.
If that still fails with 4.0.2 then please try against 4.2, and if it
fails there then please report a bug.
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
